Old 06-24-2012, 11:05 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Default Hid Help PPPLEEEEAAAASE
Iam starting to get a little bit of water in my head lights. I would to see if any one can share some pictures of Hid installs. I know the back of the headlight has a circle twist off dome cap , do you drill through that?
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 06-24-2012, 11:36 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
Yes you can, that is how you install the HIDs on the quad headlights
CLICK HERE, THIS IS BY FAR THE BEST THREAD ON HID INSTALL
MATT
Old 06-24-2012, 11:58 PM
5.7ram's Avatar
Vehicle: 2010
Thanks Brother....
Old 06-25-2012, 12:59 AM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
Why do you have water in your headlights? Did you already try to install HIDs?
Old 06-25-2012, 03:35 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
I drilled the hole in the round cover but got condensation in the drivers side light. So I took it out, dried it really well with a blow dryer for quite awhile and then when I reinstalled it, I used some clear silicone around the rubber 'plug' that goes in the hole I drilled. No more condensation So far, the passenger side hasn't had an issue so Ive been lazy but really should just pull it out and throw on a bead of silicone
