tonneaucovered.com
Old 07-08-2012, 08:55 AM
Bent21606 Bent21606 is offline
Vehicle: 2011 dodge ram
Trim Level: Big horn
Color: grey
Rep:18
Bent21606 is on a distinguished road
Yes mine was on a coasting Downshif too. For some reason it seems to have gone away for the time being
Old 07-09-2012, 08:09 PM
ArmyRXP's Avatar
ArmyRXP ArmyRXP is offline
Vehicle: 2011 RAM 1500 SPORT
Color: Deep Cherry Red
Rep:21
ArmyRXP is on a distinguished road
Unhappy
Originally Posted by chilock View Post
mine just started doing this. It is slowing down under 50 to 45 it downshifts pretty hard.
Never noticed this before. You say there is a tranny flash for it? I am out of warranty but do have the lifetime I added with the $100 deductable. would think they would check it for free......right?
Yes there is a flash update. Mine would downshift hard that the wife even noticed it. Shifts fine now and a little boost in mileage too.
Old 05-24-2013, 01:22 PM
SnowDogg19 SnowDogg19 is offline
Vehicle: 2007 Dodge Ram
Trim Level: BigHorn SLT
Color: Burgundy
SnowDogg19 is on a distinguished road
This is the problem I'm having and trying to learn about. It happans in town, usually coasting no throttle to a stop from 30 mph down. I'm thinking of getting a FlashPaq; anyone know if this will perform the quicklearn function mentioned above? I have a code reader and it's not throwing any codes.
Old 05-24-2013, 02:05 PM
Color: Burgundy
Old 07-17-2013, 09:38 AM
mge1's Avatar
mge1 mge1 is offline
Vehicle: 2014 Ram 1500 Crew Cab
mge1 is on a distinguished road
Send a message via AIM to mge1 Send a message via Yahoo to mge1 Send a message via Skype™ to mge1
Originally Posted by TransEngineer View Post
Bent21606,
Are you talking about a coastdown shift (closed throttle, coming to a stop), or a kickdown shift (like when passing another vehicle)? Is it one particular shift (like a 4-3) that's hard? Or is it all of the shifts? Does this happen only occasionally, or every time? Does it happen both cold and warm?
Mine is a 2010 and it does the coastdown shift and when its warm (from 4-3). It's annoying! Whats the fix if any? Btw 86K on my 2010. Just started recently, or lets say I never really noticed it til recently.
Calling dealer now. Hopefully they can do the Flash, we'll see.
Old 07-17-2013, 12:15 PM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:450
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
See if you can figure out which shift is harsh. Use the ERS buttons on the shift lever to limit the top gear, then try a coastdown from each gear and see what you get. Get up to speed so you're in the max gear each time. Note that ERS "3" is an extra gear (we call it 2nd prime or 2P). Here are the shifts you should get (on coastdown to a stop) from top gear in each ERS position:
ERS "2" = 2nd gear max, you'll get a 2-1 downshift
ERS "3" = 2P max, you'll get a 2P-1 downshift
ERS "4" = 3rd (direct) gear max, you'll get a 3-1 downshift
ERS "5" = 4th gear max, you'll get a 4-3, then a 3-1 downshift
"D" = 5th gear max. I think you'll get a 5-4, then a 4-3, then a 3-1 downshift
Give it a try, and see if it's one particular shift that is harsh all the time.
Old 07-17-2013, 01:27 PM
mge1's Avatar
Just got back from the stealership and they did the ecm flash... Was hoping it would be covered under warranty but with no luck, I paid the $52. Drove it back and it seems to be fixed. Lets hope it stays that way for a while.
Good thread here thanks!
Old 07-17-2013, 01:44 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2015 Crew Cab 1500 Sport 4x4
Rep:19
blackpearldodge is on a distinguished road
I notice the hard down-shift as well...while coasting to a stop.
When I'm pulling my 32' travel trailer (6,000 lbs), that's when I notice the hard "Pop" into gears (like when it's trying to drop a gear). I use Tow/Haul mode when pulling too.
There are times that, when I put the transmission into gear (from park), the truck wants to lunge forward, and quite harshly too.
Once you have Black you'll never go back! Hmmmm.....well... now that isn't quite true. I went back to WHITE!
Sport Performance Hood, OEM Mud Flaps, Factory Spray-in Bed Liner, CREE MK-R LED Fog Lights
Old 07-24-2013, 11:51 PM
D o d g e's Avatar
D o d g e D o d g e is offline
Vehicle: 2011 ram 1500 sport cc
D o d g e is on a distinguished road
Default tsb 18-023-11 flash update 2011 rams
Old 07-24-2013, 11:55 PM
D o d g e's Avatar
Originally Posted by D o d g e View Post
Attachment 37471
there was more to the tsb page for the shifting issue
