Old 06-26-2012, 12:23 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Default Precious metal hemi spark plugs
OK, we've had this discussion here before about using precious metal spark plugs in the later model hemi's, and we hear the warnings about how they don't work in the later hemi's. I don't think I've heard the bottom line, technical issue why they won't work explained here fully, but that seems to be the answer. I just did another search of this forum for the term "spark plugs" and didn't get anything new. Being that the hemi Charger police car runs precious metal plugs, I've still wondered why the other later hemi's allegedly can't.
I went to the Dodge Ram site, and tried to find some search results that might address something more about the spark plugs in the hemi...when I found this.
http://www.ramtrucks.com/en/2012/ram...ty/powertrain/
Now, I haven't pulled a plug out of my '12 Express to verify this, but doesn't that white info bubble pointing at the 5.7 hemi in this 2012 Ram 1500 segment say "platinum-tipped spark plugs"?
Old 06-26-2012, 02:22 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
who knows..maybe it does work on the 4th gens...
Old 06-26-2012, 02:42 AM
knappk6's Avatar
knappk6 knappk6 is offline
Vehicle: 2008 Dodge ram
Trim Level: Big Horn,MonsterMile
Rep:15
knappk6 is on a distinguished road
maybe they have them in there for the flex fuel. they still work with normal fuel, just not as well.
35% tint on front, 2 JL 10W1 underseat, Kenwood KVT-514, Green LED footwell lights, Spectre CAI, Nitto Trail Grapplers 295/60R20, HBS 2" Leveling Kit
Old 06-26-2012, 01:46 PM
Rep:2657
Precious metal plugs, from what i just read, are to be used only with WASTE SPARK DIS IGNITION SYSTEMs, (DIS stands for distributorless ignition system),
Here is the full article from Autolite Spark Plugs, it further explains Waste Spark Systems
http://www.aa1car.com/library/sparkplugs_for_dis.htm
Old 06-26-2012, 02:13 PM
chefred112's Avatar
Rep:656
hmm..it didn't work with mine..but then again, that could be the pcm not liking the resistance output and probably fell out of range that the sensors said something is misfiring..
Old 06-26-2012, 02:30 PM
TNC TNC is offline
Rep:12
Very interesting link to that info, GT. I see one problem, however, as it relates to many/most motorcycles with multicylinders and one-coil-per-two-cylinders. These have a "waste spark" and they have no distributor. Whether they run standard plugs, precious metal plugs with just one point, or precious metal plugs with two precious metal points, there doesn't seem to be an issue of excessive wear because of this. Obviously the precious metal plugs of either kind show to last longer in these applications, and that's somewhat logical. I'm a little curious as to their assessment about electrode degradation because of the firing on the exhaust stroke. The firing of the plug under compression and with a fuel combustion is a tough environment for a plug to be sure, but on the exhaust cycle, I wouldn't think the plug's effort or result is anything nearly as tough on the plug. Granted, on the molecular level, there has to some additional wear with another spark, but when that spark is in a less hostile environment, that has to be somewhat of an advantage.
And GT, there is a clarification in their description of what precious metal plugs are...single-tipped or double-tipped. The info in that Ram site 5.7 segment doesn't clarify which style they're using, so that's still up in the air a bit. When I've used precious metal plugs in a myriad of vehicles over the years, I've always used the dual-tipped version if at all available.
Old 06-26-2012, 10:02 PM
HemiLonestar's Avatar
Rep:274
Iridium's with shorty's work just fine on mine.
"Big Red"
2006 Charger R/T
