Old 06-26-2012, 01:51 AM
deadbroke deadbroke is offline
Vehicle: 2006 dodge ram mega cab
deadbroke is on a distinguished road
Default upgrade speaker wire front doors
i am in the process of upgrading the wiring for the door dpeakers on my 2006 mega cab and am finding it hard to access the connectors for the front doors. it almost looks as if i have to remove the dash and the air conditioning unit to get to this connector for the door. do you guys have any suggestions or ideas on how to get access to this connector?
Old 06-26-2012, 11:39 PM
nothing from no one? i am determined to get a reply out of someone here on this forum in this thread.
Old 06-28-2012, 12:04 AM
ImAHemi ImAHemi is offline
Vehicle: 09 Ram QC
Color: Deep water blue pearl
Rep:24
ImAHemi is on a distinguished road
If it is anything like the 4th gens;
I took a pick to remove the boot from the plug.
Used a small flat head to depress the 4 clips (2 on top and 2 on bottom) a corner at a time.
I pulled the connector out of the truck.
I disconnected the plugs in the connector.
I hope it helps but I haven't tore apart a 3rd gen.
Old 06-28-2012, 02:31 AM
seems like i have worse problems. i ended up messing around with the plug yesterday took off the parking brake mechanism and then pulled the plug out to see how they routed the wires for the viper alarm window module put it together and tested it all good. i go in today so they can install the rear module and they checked it and the only window that wouldnt work is the drivers side it wont control any of the windows from the drivers door but all the rest work on their own panel. the wiring on the drivers side wasnt too bad to remove once the parking brake was pulled away from the sheet metal
