Old 06-26-2012, 07:50 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Default weight vs. tire/wheel combo
well let me start by saying i have the stock 20's that weigh about 39 lbs per and the stock 275/60/20 tires which ill say weight maybe 10 ish? so a total of 40-50 ish? not to to sure. i have a smaller rim and more meat on my tire compared to what i want which is 22" liquid metal blades which are roughly 40 lbs and nitto 420's 305/45/22 which im going to assume are 10 ish pounds.
so my question is, with a bigger rim/tire combo, even tho my weight is similar to my stock ones, will it effect my gas milage alot? my friend had 305/75/17 mud tires and he gets 10 mpg...the tire has more touching the ground(305) so will it hurt me much?
http://www.discounttire.com/dtcs/fin...2973&rc=TNWINT
http://www.discounttire.com/dtcs/fin...12973&sw=false
-Pat-
Old 06-26-2012, 05:59 PM
moparornocar72's Avatar
Rep:630
anytime u have bigger tires or more rolling resistance there is a chance ur gas mileage will suffer. However the nitto tires are better then ur goodyears and probably weigh less then them also!
14.268 @ 95 MPH Full Trim
Old 06-26-2012, 09:14 PM
Rep:3322
You'll have a heavier rotating mass as the bulk of the wheel's weight is further away from the center hub. Your fuel mileage won't really suffer, but you'll notice a decrease in your brake effectivness. Oh, the 420S 305s weight just under 15lb a piece, I know, I run them myself on a set of D'vinci Ragno 22s. I would highly recommend a brake pad upgrade to help slow the heavier combo.
Old 06-27-2012, 01:26 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
not to be a jackass but are you guys serious about these tire weights? I'm currently researching what tires I should buy next and I think you guys are way off. our stock goodyears are in the low 40 lbs each for just the tire and the Nittos are in the mid 40s lbs each tire.
Old 06-27-2012, 01:37 AM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
They are right about nittos weighing a little less on the same size tire but yeah LOL the weight of the tires are far off (40lb range). My 305 45 22 nittos 420s weight 42.5 and so do the stock goodyears 275 60 20.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 06-27-2012, 05:24 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
x2 on the tire weights. My 26x4.5x15 skinnies are in the 12lb range lol
OP, you wont notice it as much as you think if you just drive the truck and dont sit there and focus on them
2011 Big Horn 4x4 -SnowWhite-
Old 06-27-2012, 07:47 AM
BlackHemI's Avatar
Rep:296
thats what i was thinking that the 305 nittos arent to to heavy, they are a thin tire and the size i want are 305/45/22, so maybe thatll help me get a figure from you guys. i have ebc green pads, would that help?
-Pat-
Old 06-27-2012, 12:24 PM
Rep:111
Yeah that will help, like I said I have 22's with the nittos 305 45 22 tire and I have no problem stopping (stock brake pads). Beside the nittos will grip better than most tires out there so you should have a problem going with them at all.
Old 06-27-2012, 12:43 PM
BlackHemI's Avatar
Rep:296
how much mpg did you notice you lossed when you switched from your stockers to your rims youve had
-Pat-
Old 06-27-2012, 01:23 PM
Rep:111
I averaged about 16.9mpg before the wheels and that was 70% hwy 30% city...took a loss of about .5 -.7mpg but only ran maybe 1 1/2 tanks before adding headers and a 2/4 drop. I'm back up to about 17.3mpg after the other mods....theirs always a price to pay for better looks.
