Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-26-2012, 09:36 AM
shanemacdonald234 shanemacdonald234 is offline
Vehicle: 2002 Dodge Ram 1500
Color: Block
shanemacdonald234 is on a distinguished road
Default oil pressure
Ive been having a problem with my oil pressure for a while now. after running for about 20 minutes or so and come do a stop my oil pressure will drop and as soon as i hit the gas again it goes right back up to normal. i just changed the oild and ran a 5 minute engine flush to see if there was a clog in the line or the screen but this morning on my way home from work it did it again. this time it would drop and go up a quarter of the way then drop and back up then it stayed down so i popped the hood to see if there was a leak or any noise but i had nothing so i pulled the dip stick and put my finger over the hole for a second and took it off and checked the gauge and it was back up to mormal. i dunno if that was related to me taking out the dipstick or what but at this point im stuck and needing so advice
Old 06-26-2012, 10:21 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
The oil pressure will drop with RPM..usual rule is 10psi for each 1,000 RPM. My 2010 idles at about 18 psi and runs at about 43 during highway travel.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 06-26-2012, 10:25 AM
Color: Block
It bottoms out and the check gauge light comes on.i should have been more clear on that sorry
Old 06-27-2012, 03:40 PM
latitud's Avatar
Rep:71
I would change the sender as a precaution.
