Old 12-09-2012, 02:15 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Default Tailgate fails to latch when cold
Looking for help from the rest of you up here in the great white north. I'm having an issue with my '12 RAM. As the temperature drops, I have more and more trouble getting the tailgate to latch.
It generally starts to happen around -15C, the tailgate often needs to be slammed about 5 times before it will latch. This morning around -28C it would not latch at all.
I don't think this is unique to the G4's, as my '97 Ram had similar issues and so did my '05 Dakota, although not to the same extent.
Anybody else have this problem, if so did you manage to solve it?
Thanks,
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 12-09-2012, 04:21 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Thanks,
Yep, I have been having this problem for the past month or so. We had a -30--40F spell for a week and a half so it wouldn't close for almost 2 weeks. I brought it to the dealership for something unrelated and they "thawed out" the tailgate and closed it. They told me that there was nothing they could do, not even grease would help.
BTW when it get that cold, does your transmission have different shift points?
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 12-09-2012, 04:27 PM
ExpensiveToys ExpensiveToys is offline
Vehicle: Ram
Rep:7
ExpensiveToys is an unknown quantity at this point
While I haven't had trouble with the tailgate, in the past have had trouble with door latches and once a problem with the hood. As near as I can tell lube on the latches was either freezing or increasing in viscocity to the point the lube was actually causing latches to stick.
You might need to clean up the tailgate latches and give them a good lubrication with a good low temp rated lithium grease. Its sort of become a yearly ritual on my rigs that before the winter hits I make sure door latches, hood latch, and tailgate latches are clean of debris and lubed up.
Old 12-09-2012, 07:04 PM
Wizza's Avatar
Wizza Wizza is offline
Vehicle: 2012 Ram CTD 2500 4X4 Laramie
Color: White/Silver
Rep:119
Wizza will become famous soon enoughWizza will become famous soon enough
Agreed on the lithium grease....
http://ramforumz.com/picture.php?alb...ictureid=12320
S&B Intake, MBRP Cool Duals exhaust, 4" MOPAR lift, NFab step bar, Anthem Offroad Defenders 20X9, Toyo AT II 295/65-20, V-LED backup frame, LED reverse lights
Old 12-18-2012, 04:55 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
WD40 to clean them up, then lithium grease. My '95 Dakota used to do this when new, and when we lived in WI. The dealer sprayed something in there -- that cured it.
Old 12-18-2012, 05:33 PM
Rep:2616
you could try
FOOD GRADE SILICONE or FOOD GRADE MINERAL OIL
or
3M 08897 Silicone Lubricant (Dry Type) - 8.5 oz.
"High quality silicone lubricant which eliminates rubber squeaks, prevents sticking and seals out moisture"
This product contains no petroleum oils to stain fabrics and will not freeze at -28 degrees F nor degrade at +350 degrees F
Most Lithium grease is only good to -5 F
Old 12-20-2012, 04:13 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
You can also pull the cover plate off the inside of the tailgate and stretch the springs inside to put more latching force on the mechanisms that grab the posts either side. It's a major PITA but it seems to work on most trucks. As noted above my first option would be to wd40 (water displacement) the mechanism and then lithium grease
