Old 02-09-2012, 11:00 PM
cesarcal cesarcal is offline
Vehicle: 2001 Dodge Ram Sport
cesarcal is on a distinguished road
Default Do I have a lift? and will they fit?
I have done a search on here but after reading some posts it appears my truck is either rare or not stock. I just bought a 2001 Ram Sport RCSB 5.2l with a 5 speed. The tailgate does have the Off Road and 4x4 stickers on the tailgate but nowhere else. So with that said I am looking to get new tires and really like the look of it now but am unsure if I should stick with 35x12.5x17 like it has now or go a little shorter. Thereis a little rubbing on the inside rear plastic of the fenders but nothing major and am affraid once I get the new ones the rubbing will be much worse. Any suggestions or ideas?
Old 02-10-2012, 03:48 PM
semisane semisane is offline
Trim Level: Laramie/Sport
Color: Fire Red
semisane is on a distinguished road
there is a wheel/tire gauge tool available that lets you check for clearance and helps you pick the right offset for the wheels.
I have changed to wheels with different offsets before to gain clearance.
Just know that changing offset will also change load on bearings and axles.
Old 02-10-2012, 04:16 PM
The tires on it now are 35x12.5x17 but are pretty worn and dont want to spend the money on new ones if they are not going to fit properly or if I am going to have to modify the front bumper for them to fit. Actually im looking at 315/70/17 retreads from treadwright and the diameter I beleive is like 34.7.
Old 02-15-2012, 09:49 PM
Gages1995Ram's Avatar
Gages1995Ram Gages1995Ram is offline
Vehicle: 1995 Dodge Ram
Color: Green/Silver
Rep:69
Gages1995Ram will become famous soon enough
That truck definitely looks lifted. I'm running 315's on my stock 95' and they rub on my bumper only when I turn my wheels all the way. If your running 35"s now, you should have no problems with 315's.
1995 Dodge Ram 1500 SLT 4x4
Old 02-15-2012, 10:05 PM
Knuckles Knuckles is offline
Vehicle: 2003 Dodge Ram 2500 5.7 4x4
Trim Level: SLT Heavy Duty
Color: Gun Metal Gray
Knuckles is on a distinguished road
Looks like the tires rubbed enough in the front to bend down the front bumper like that. And if they rub a little with bald tires, if you get the same size with full tread its definitely going to rub a lot more. So if you dont want to modify your truck any more your going to need to run a little bit smaller tires.
Good looking truck BTW, I like the color combo and those headlights are sweet
Old 07-12-2012, 04:18 AM
bcaraway's Avatar
bcaraway bcaraway is offline
Vehicle: 2001 Dodge Ram Sport Off-Road
Trim Level: Sport Off-Road
bcaraway is on a distinguished road
I have a 2001 Dodge Ram 1500 Sport Off-Road Edition and my truck sat just like that with 35" tires with no lift at all. I would say that there is no lift on your truck. And I would recommend a 2.5" coil spacer for the front which will fix your rubbing problem. You can find them anywhere, just bought mine from eBay for about $65. Stay with the 35's definitely!
Old 07-14-2012, 10:11 AM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:45
TinMan68 is on a distinguished road
If it says 4x4 Offroad on the tail gate then it has a special package on it. Which Includes a 2 inch body lift and 4:10 gears from the factory it probably also has positraction in the rear differential.
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
Old 07-19-2012, 11:35 AM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
What the tailgate is not stone run your vin and find out for sure. Dosen't take much to throw a different tailgate on a truck. Either contact Dodge dealer or try this it helps some but the stuff you are asking a dealer will be able to tell you.
http://dodgeram.org/tech/specs/VIN_decode.htm
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 07-20-2012, 06:10 AM
bcaraway's Avatar
It's not a body lift, It gets the extra 2 inch lift from stiffer coil springs and leaf springs.
