Old 04-21-2011, 07:15 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
Default 4th Gen HP Peak
Does anyone know at what rpm the 4th gen hemi makes its power peak? Is there a difference between what the manufacturer states and what someone has found on a chassis dyno? I've been playing with my WOT shift points on my Superchips tuner. Currently I have it set at 5950rpm, but it seems like I may be revving too far past my powerband.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 04-21-2011, 11:59 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Be careful, these fourth gen Rams with the Eagle Hemi can't rev as high as the previous generation due to the valvetrain.
Old 04-22-2011, 01:42 AM
Rep:2640
my stock Ram, 2 dyno runs, first one you can see where it shifted
I hope someone can read it, because i am lost
[IMG] [IMG] [IMG]
Old 04-22-2011, 08:52 PM
JmegacabinGA JmegacabinGA is offline
Vehicle: 2006 Ram 1500 Mega Cab
JmegacabinGA is on a distinguished road
Based on GTyankee's dyno results, looks like the peak is right around 5275. Maybe someone smarter than me can be more accurate than that, but I'm calling it how I see it.
Old 04-23-2011, 10:43 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
From your dyno results which are very close to mine.
Peak HP is at 5300 RPM:314:74 HP.
Peak tq is at 4400-4500 RPM:327:48 TQ.
There is no reason to raise max RPM above stock,unless your racing and your using 93+ octane gas cause your going to get some knock.
Looks to be a good 3rd gear dyno pull before it spiked and shifted into 4th gear.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 04-23-2011, 12:27 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I would change your WOT shifts to 5500 rpm...just above peak. By the time the trans shifts you'll still be in the meat of your torque/power band you won't risk over-revving it.
Like already stated it looks like peak hp is around 5300 and peak torque is around 4250-4500.
Old 04-23-2011, 01:40 PM
chithead's Avatar
Rep:2078
I bumped mine up to 5850 on the 1-2 shift and 5800 on 2-3 shift. Going to see how it performs...
Old 04-23-2011, 08:27 PM
Color: Mineral Gray
Rep:72
Thats about as high as Superchips works,before it starts producing a slower shift.
You need to raise your rev limiter also or else it wont shift.
I would raise it to at least 6100 RPM.if your going to be shifting at 5850 RPM.
I think Superchips has a safety feature to force you to raise the rev limiter before the shift RPM???.
I lower my tq managment also to help it shift quicker.
3:92 gears.
Old 04-26-2011, 11:59 PM
dustin72's Avatar
Rep:48
Going to make a few runs shifting at 5800rpm, then switch to 5500rpm and see if my ET and MPH picks up. Will keep you posted.
Old 04-28-2011, 03:15 PM
barn's Avatar
barn barn is offline
Vehicle: 2010 ram sport
barn is on a distinguished road
Mine stopped gaining at 5300 rpm torque started to drop at 4300 rpm.
Hemi Hat Sneak Peak Crash Custom Dodge Ram Interior and Exterior Lighting 54 07-26-2012 05:33 PM
Sneak Peak Mufflex Tips JEC Exhaust 16 01-28-2011 09:28 PM
Sneak peak from the dealer Indeepcamo 2010 Dodge Ram Forum 9 04-08-2010 08:19 AM
Header Question ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 31 03-17-2010 07:24 PM
