Old 06-27-2012, 05:51 AM
Raneman's Avatar
Raneman Raneman is offline
Vehicle: 2004 Dodge Ram
Rep:22
Raneman is on a distinguished road
Default LED load resistors
I want to get these, http://www.gorecon.com/product.php?p...hback-LED-Bulb , but i'm confused on what resistor to use. I read on the "led fix" sticky that to fix any issues you need to use a 100 ohm 1 watt load resistor...but if you read the 6th paragraph on that recon page, it says to use a 6 ohm 50 watt resistor... Which one?
And can you just put the resistor in the wires before the bulb? Id rather do that then solder it on the led. Wire is alot cheaper then those leds!
Mopar or no car
Old 06-27-2012, 06:15 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
6ohm 50 watt are used for LEDs that flash (brake lights/front markers)
2011 Big Horn 4x4 -SnowWhite-
Old 06-27-2012, 03:10 PM
RUMBLE BEE 1546's Avatar
RUMBLE BEE 1546 RUMBLE BEE 1546 is offline
Vehicle: 2004 Doge Ram 1500
Color: Solar Yellow
RUMBLE BEE 1546 is on a distinguished road
I'm waiting for these. I like them over any other switchbacks because they are type 1. It switches from amber to white when blinking insert of just flashing amber.
http://www.v-leds.com/6K-TYPE-1-DUAL...68713-1-2.html
And these resistors are what you'd use.
http://www.v-leds.com/Load-Resistors/c343525/
Old 06-27-2012, 05:29 PM
SS4Luck's Avatar
Rep:310
If I had the ambers in my mirrors still I would have got the dual colored frot blinkers too but mine are white in my mirror so I got all white for the frot as well
Those dual color blinkers are nice for people that dot want to push te "illegal" envelope as hard as others
Old 06-27-2012, 05:31 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
try www.superbrightled.com for resisters
Old 06-27-2012, 06:24 PM
Raneman's Avatar
Rep:22
Thank you! Exactly the answer I was looking for.
Thats what the ones in the link I posted do. And thanks for the resistor link!
Mopar or no car
Old 06-27-2012, 07:25 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
you get the same exact ones at super bright for way cheaper
Old 06-28-2012, 01:19 AM
Raneman's Avatar
Rep:22
Well I'm getting them from ebay for even cheaper. Thats where I got my backup lights that are the same, just all 60 leds are white, no problems and Ive had them on for a few months.
Mopar or no car
Old 06-28-2012, 04:50 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
ya only thing bad about ebay is that stuff comes from japan so retuning would be a hassle
