LOC Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-27-2012, 04:16 PM
Braap105's Avatar
Braap105 Braap105 is offline
Vehicle: 2011 Dodge Ram
Color: Blue
Braap105 is on a distinguished road
Default LOC Help
Well Ive been reading around a lot about these things because i want to put my sub+Amp that i already have from my old truck into my 2007 dodge ram.
From looking it seems like a Pac SNI-45t would be the easiest and pretty inexpensive ~$25.
It seems all i would need to do is tap into my rear speaker lines? were as other LOC seems to do that same but also do NOT have a remote trigger for the amp.
Has anyone ever used one of these or know anything about if they are any good?
Old 06-28-2012, 11:24 PM
DuckNovaCain DuckNovaCain is offline
Vehicle: 2008 Dodge Ram
DuckNovaCain is on a distinguished road
Installed one last night. Honestly.
Its my first time installing a sound system and I put two Kicker CVR 12s in with a 750 watt Kicker amp. I installed everything last night in my 2008 Quad Cab and it went pretty good.
The LOC was SIMPLE...not neccessarily EASY. Again, I'm a first-timer. It wasn't a hard concept to grasp, you just had to be sure you had all the wires right. I followed the directions that came in my LOC and spliced the four wires into my right front pos, right front neg, left front pos, and left front neg wires in the back of the stock radio. This thread link should help you be sure you get the speaker wire colors right:
http://www.ramforumz.com/showthread.php?t=48167
As far as the remote turn-on wire, the LOC didn't have a connection for that. I just tapped (as someone else did on here) into the hot wire on my left 12V outlet (or the actual cigarette lighter plug) which is a "key-on" only outlet meaning when the key is out of the ignition, it doesn't stay on. This is important, so as not to drain your battery. If I would have tapped into the 12V outlet on the right of my dash, it is a "constant-on" port and I'm pretty sure my amp would drain my battery overnight.
-----EDIT------
To clarify, I installed A LOC last night. I'm not sure the model number. When I said mine did not have a remote lead for the remote turn-on, I wasn't meaning the one you were looking at was not going to come with one. The LOC I purchased, did not.
I'll check tomorrow for my model number and try to post on here.
Old 07-04-2012, 05:34 PM
Hey man, sorry it took me so long to get back to you with that model number. My family has been on vacation. The model of LOC I purchased was the PAC SNI-15.
Hope this helps.
