Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 06-27-2012, 05:59 PM
fredski fredski is offline
Vehicle: 2012 Ram 1500
Trim Level: express
Color: red
fredski is on a distinguished road
Default McGuaghy 2/4 lowering kit
I want to install the 2/4 lowering on my 2012 Ram 1500. Do you have to use a coil spring compressor to remove the FRONT coil springs?
Old 06-28-2012, 04:37 AM
hnrypat21's Avatar
hnrypat21 hnrypat21 is offline
Vehicle: 2012 Dodge Ram
hnrypat21 is on a distinguished road
no not if your careful you can just use a jack and lower it down it should just fall off at that point worst case a couple twists of a pry bar or a whack with a rubber mallet should get it off... just ordered the McGaughys 2/4 kit i will do a right up of install the only difference is that i am going to cut a coil or 2 off of the springs to have it sit as close to 3/5 as i can
Big Man Certified
