Old 06-27-2012, 11:16 PM
hunter.shawn's Avatar
hunter.shawn hunter.shawn is offline
Vehicle: 2000 Dodge Ram SLT
Trim Level: SLT Laramie off road
Color: Pearl garnet
hunter.shawn is on a distinguished road
Default Check it out!.. New acc. One New Problem
Allright... I have been stuck between work and family for too long.. I miss the Z haha!... Some pictures Have been attached to this post! I have mixed my own plastidip and plastidipped my new brushguard/rollbar and rear bumper/front bumper and my wheels!.. Loove the results, opinions would be great!.... Onto my question, I am stumped... When I have drove for about 10 miles or so and the driveline is all hot.. I begin to hear a whiirrring/groaning sound from somewhere in the driveline (only on take off into a turn, or parking lot maneuvers/slow turning reverse.. Cannot pinpoint it, U joints are all good.. fluid in the rear diff has 15,000 miles on it, all the fluid in the front diff/tranny/transfer case is all brand new Lucas 80/90.... The sound only remains for about 2 seconds then it subsides...Maybe my clutch packs are wearing out? I find that unlikely due to the meticulous care of this truck and due to the fact that it sees little abuse and has not towed a trailer since my purchase of it..any suggestions are helpful...Problem could be in the front end from all I can hear haha.... Also!My water pump blew out about 2 weeks ago... It blew dramatically haha! Spewing coolant from the upper seal like a sprinkler.. Needless to say, it was a replacement job...Buuut I took it a step further and replaced my timing chain also.. That was a job and a half,glad it is done though... The hardest part was removing the old water pump from the fan..Sweet jesus that sucked... Timing chain was a little wore with some play to it but nothing major... Made a video on the process if anyone is interested.. It can be done with normal tools.. Only special tool you may need is a 3 prong puller or "Chickenfoot" to yank that harmonic balancer.. anyways, would love some opinions of the groaning driveline/possible steering issue!
women< my dodge
Old 06-28-2012, 09:14 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
When you did the axls did you add or check about adding friction moddifier to gear oil?
Old 06-28-2012, 10:53 AM
Color: Pearl garnet
At Ramfam, yeah I added the modifier with the gear oil when I changed it out... the lucas gear oil I use states on the bottle that it does not need any special additives, but, I added it anyway.
women< my dodge
Old 06-28-2012, 12:00 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Well that's good I know the daina rear ends will. Lock up and skip and bark without it and the front will groan when not locked in 4x4
Old 06-28-2012, 12:05 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Do you have a manual or auto trans? My 01 5 speed is good for being a whiner at low speed forward and back. And the 95 4x4 is good for rearend whine.
Old 06-28-2012, 11:20 PM
Trouble's Avatar
Trouble Trouble is offline
Vehicle: 1997 ram 1500
Color: red over silver
Trouble is on a distinguished road
By the way your transfer case should have atf+4 in it.
Old 07-01-2012, 11:10 AM
Color: Pearl garnet
It is an auto... The rear end has never been noisy although The sound vibrations reverberate through the steering column...Trouble- Yeah, the tranny and T-case have Castrol Max-Atf -4... Everything else in running on Lucas oil
women< my dodge
