Old 06-30-2012, 03:33 PM
MvZiC MaN's Avatar
MvZiC MaN MvZiC MaN is offline
Vehicle: 2001 Dodge Ram
Trim Level: Base
Color: Matte Black
Rep:32
MvZiC MaN is on a distinguished road
Send a message via Yahoo to MvZiC MaN
Default 3" Front coils spacers + 3" lift blocks???
i have a 01 Ram and i was wanting to lift it around 3" so i could fit bigger tires but i can afford an actual Suspension Lift and i DO NOT like body lifts because they cause to many problems so my alternative was to buy a 3" leveling kit
but a leveling kit is meant to Level the truck so it was 3" coil Spacers in the frot and 2" Blocks in the back
if i were to buy 3" Spacers and 3" Blocks would that do what i wanted and would it be Safe??
here are the links to the Parts i want to use
Coil Spacers
http://www.ebay.com/itm/280874893232...84.m1438.l2649
Lift Blocks
http://www.ebay.com/itm/280899508712...84.m1438.l2649
If guns kill people than i should start blaming my Keyboard for Spelling Errors
Old 07-08-2012, 04:27 PM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
i know on my 4x4 with a 2.5" leveling coil spacer the stock shocks just made it so you might need longer shocks. as for the rear block you will be good, alot of people dont like stacking blocks but alot of lift kits come that way, i added a 4" block to my factory block and all is good. i think you should be good to go just get longer shocks.
Old 07-10-2012, 12:18 AM
MvZiC MaN's Avatar
Trim Level: Base
Color: Matte Black
Rep:32
well i just ordered them and will take pictures after i get them installed.... I need to do an update anyway..... cuz ive done alot to it lately
Old 07-19-2012, 11:41 AM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Save up for control arms I don't like anything over 2" spacer you start to loose up size for the wheel being pulled back torwards the cab.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
2nd gen ram, leveling kit, lift
