When will gotbrains230 get his cab lights installed? - Page 13 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
View Poll Results: When will gotbrains230 install his cab lights?
When he gets a round tuit 2 15.38%
When he gets a square tuit 0 0%
When he finds a drill bit to make the hole smaller 2 15.38%
When the lights install themselves 8 61.54%
Once LA passes a bill making HID cab lights manditory 0 0%
All of the above 1 7.69%
Voters: 13. You may not vote on this poll
Old 07-08-2012, 01:54 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
6 ohm 50 watt, or maybe vise versa
I put the resistors on all but the passenger tail, and got hyperflash on left and right turn
They are probably tapped in on the wrong wire(s) because it should go away
For me with my switchbacks it went away the moment I installed the resistors.
By the way, where did you grab your resistors from?
sales@revelperformance.com
Old 07-08-2012, 01:57 AM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
superbrightleds
is there a specific way theyre supposed to go in? I hooked one end to turn signal wire and other end to ground
Now something to remember, is my turn signal wire is in a wire nut with the turn wire for the light under the truck, and the cab light.
MATT
Old 07-08-2012, 02:00 AM
Revel Performance
Rep:1804
superbrightleds
Mine were from them as well.
All I know is for the front and I grabbed the 2 outer wires. One was ground and one was for the flashers
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
6 ohm is the right one.
You do need to install all 4. It is often best to install them right at the bulb for ease in identifying the correct wires. BTW - The 'Must' be installed across the wires, NOT from the bulb hot to ground. Your truck uses the 'negative' side of the bulb as a return line so it is part of the bulb condition test circuit.
brad
Interested in one of my mods?
Old 07-08-2012, 02:08 AM
Rep:420
What do you mean by this
the resistors has 2 wires, i took one and hooked it to turn signal, and the other to the ground...did I do it wrong?
MATT
Old 07-08-2012, 02:19 AM
brad12kx's Avatar
Rep:2581
Correction !!!! The turn signal bulbs do use normal ground as the return. I've had my mind on headlights......
Mind now focused on turn signals..... LOL
You need a resistor on each of the circuits that have LED lamps for turn signals (assuming 4 in your case). This resistor connects from the turn signal wiring to ground.
Just take particular note as to which wire you attached to. They are all different colors and is easy to get them mixed up.
brad
Old 07-08-2012, 09:26 AM
Rep:420
OK thanks, im gonna play around with them today and see if I can get it to work
MATT
Old 07-08-2012, 11:21 AM
Revel Performance
Rep:1804
GB230, again....i only did my front turn signals and i connected the resistors to the wires connecting to the bulb.
I did grab the 2 outer wires (there are only 3) so don't bother looking at the middle wire.
Im not sure if the rear is the same, but I do not see how.
But as Brand mentioned, they are different colors but again, I grabbed the 2 outer wires.
Old 07-08-2012, 04:26 PM
Vehicle: N/A
Rep:1045
i just bought an aftermarket flasher that replaced my blinker relay.... works like a charm!
Old 07-08-2012, 11:00 PM
JHemi1's Avatar
JHemi1 JHemi1 is offline
Vehicle: '11 SLT Crew w/Rambox Coolers
Rep:30
JHemi1 is on a distinguished road
been a few pages since we saw the wifey, thought I'd bring her awesome expression back for everyone's enjoyment lol
Btw, superbrightleds.com rocks. Always willing to help the extra mile, plus they're local.
