Hemi Clutch Fan on while cold? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 06-28-2012, 08:06 PM
eldorado99 eldorado99 is offline
Vehicle: 2012 RAM
eldorado99 is on a distinguished road
Default Hemi Clutch Fan on while cold?
Hi, my 2012 Ram 1500 Hemi's clutch fan is always on for the first five minutes of driving when it has not been driven yet that day. It is annoying because all you can hear is the fan while driving until it warms up, is this normal? Once the engine warms up the fan dies down and everything is normal.
Old 06-28-2012, 11:32 PM
northtropics northtropics is offline
Vehicle: 2012 Ram 1500
Trim Level: bighorn
Color: Deep Cherry Red
northtropics is on a distinguished road
Mine does the same- just the nature of the beast.
Usually takes me about 1/2 mile , then it quiets down.
Old 06-29-2012, 12:09 AM
jacobson.s's Avatar
jacobson.s jacobson.s is offline
Vehicle: 2016 Ram 1500
Color: Pearl White
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:61
jacobson.s will become famous soon enough
I think it does this to prduce load on the engine. More load, the emgine warms up a little faster. My 2005 did this as well. It's normal.
Old 06-29-2012, 12:15 AM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Normal for about a block and / or when the engine spins up past about 1,500 rpm.
Five minutes? Not normal - unless that five minutes was at idle.
Old 06-29-2012, 11:34 AM
Cobrajr's Avatar
Cobrajr Cobrajr is offline
Vehicle: 2015 Ram 1500
Trim Level: Longhorn
Color: Western Brown/white gold
Rep:14
Cobrajr is on a distinguished road
Mine does it too, I like the sound :P
Mods: None
Planned:Catch can - Cabin Air Filter - More!
Old 06-29-2012, 02:11 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
never noticed this ...I will so now, which may be a good thing or bad thing
sales@revelperformance.com
Old 07-02-2012, 11:43 PM
Audacious Audacious is offline
Vehicle: 2012 Dodge Ram 4x4
Audacious is on a distinguished road
Well it can depend on different things. I had an old 1995 dodge dakota with the 318 and regardless of outside temp the fan clutch always engaged on startup. My technical service manual said it's to spin the fluid inside the clutch because it has sat for some time. If it is really cold I could see it need to spin for longer to cycle the fluid.
Also if you have either heat or ac on at startup it will turn on your electric fan which is also quite loud.
I wouldn't worry too much unless your truck either doesn't warm up or overheats.
Old 07-03-2012, 09:12 AM
SFVDOC's Avatar
SFVDOC SFVDOC is offline
Vehicle: 2012 Ram 1500 CC 4X4
Rep:83
SFVDOC will become famous soon enough
Normal. Don't worry about it.
Old 07-03-2012, 09:25 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Normal, even my 20012 grand cherokee did that
