1993 250 8 Bolt wheel swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-01-2012, 03:24 PM
spazzybob spazzybob is offline
Vehicle: 2012 RAM 1500 LONGHORN
Trim Level: Laramie Longhorn
Color: Black/Gold
spazzybob is on a distinguished road
Default 1993 250 8 Bolt wheel swap
I have a set of 2006 factory aluminum 8 bolt rims and I want to install on a 1993 Dodge .Does any one know what thickness of wheel spacers work best on a 2 wheel drive.
Old 08-28-2012, 10:01 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
The rears won"t be a problem will clear everything. the front is where you will have an issue but only near full turn. The cheapy is to adjust the stops but you cut down your turning radis. The best way is go to tire rack and chec back set of both trucks and that should give you a good indication of how much back space spacer needs to be. But if your truck is a 1/2 ton You will probably have 5 lug rims and in that case you'll need 4 from 5 lug to 8 lug adapters and not just spacers.
