Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-03-2012, 02:15 PM
labook2001 labook2001 is offline
Vehicle: ram 2005 dodge
Trim Level: 4dr long bed 2wd
Color: tan
labook2001 is on a distinguished road
Default axle ratio for 2005 2500 2wd quad cab longbed
need a build sheet so I can find out what axle ratio I have. I want to haul heavy loads (two cars). Any help? I'm new to this forum so I'm not sure what info to include.
Old 07-03-2012, 06:57 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
First off, you'll get a better response if you post it under the 3rd Gen section.
However I do believe that the '05 should have an options tag in the glove-box that will give you the ratio. They used to be under the hood on the underside.
You can also check the differential housings for a tag that will give you the ratio.
If those fail, you can go to any dealership with the VIN, or contact Chrysler.com and they will supply one and advise you of any recalls that haven't been performed on your truck.
If you feel like pulling the cover off. Count the gears on the ring gear and the gears on the axle shaft gear. Divide the smaller one into the larger one.
I hope that was enlightening.
