Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 07-04-2012, 11:10 AM
SailorEd50 SailorEd50 is offline
Vehicle: 2011 Ram 1500
SailorEd50 is on a distinguished road
Question A "Thump"
Own a 2011 Ram 1500 Reg Cab Long Bed. Never noticed this before on this vehicle but now when I come to a stop (most times) I stop and then there's a "small thud" just a second after I stop. Dealer says this is normal because of the give of the bed. Correct? Or could it be something else?
Old 07-05-2012, 03:42 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Do you have the bigger gas tank? Is the thump happen when your tank is between 1/2 and 3/4 full? If yes then its because there is no baffle in the larger gas tank and its the gas sloshing forward. If you have the Evic screen on your truck disable Hill Start assist ( think that's what its called) . For some reason this helps.
Hope this solves your problem.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 12-23-2012, 10:24 AM
Bigdiezel79 Bigdiezel79 is offline
Bigdiezel79 is on a distinguished road
Had the same deal with mine disabled the hill assist and the thump went away
Old 03-13-2013, 09:08 PM
coldfusion73 coldfusion73 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4X4
coldfusion73 is on a distinguished road
http://www.ramforumz.com/showthread.php?t=132204
