Old 10-25-2011, 09:09 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Default Lowering Suspension Question
So iam ready to pull the trigger on my lowering suspension. I want to do the complete kit, springs and shocks.
2011 Dodge Ram 1500 Sport CC.
1: Whats the lowest Suspension that they make for our trucks?
2: Whats the best BRAND of suspension ?
Coils and Shocks.
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 10-26-2011, 01:18 PM
Well, McGauhey's and Bell Tech make a 2/4 mechanical drop for your truck.
Bell Tech has always made some good quality stuff.
Other options would include a full airbag set up or a set of coilovers.
I am not sure who, if anybody, makes a set of coilovers for these trucks but a bit of research may bring some up.
I have KW coilovers on my SRT and love 'em. You might check out their website to see if they have a set for the truck.
Good luck!
Old 10-27-2011, 02:13 PM
11ram256 11ram256 is offline
Vehicle: 2011 Ram
Rep:30
11ram256 is on a distinguished road
Here is what i have came up with after a little research:
Belltech seems to have the best springs as far as ride quality/tow capacity go.
Mcgaughys is the only kit that has a solution for the shorter sway bar endlinks needed to correct the angles that are present after lowering the rear.
Mcgaughys also offers a track bar relocator bracket to correct the axle shift when lowering the rear. I have heard of some people having issues getting it to line up but from my research that was just with the first batch after the kit was developed.
I have heard that Mcgaughys springs are slightly softer so you might have problems if your trying to tow a large load.
Mcgaughys claims that the kit doesnt need aftermarket shocks since the axle will hit bumpstops before the actual shock itself bottoms out. The shocks that come with aftermarket lowering kits are mainly just shorter to make sure the axle bottoms out before the shock does to keep from blowing out shocks. They are valved slightly different to give a "sportier" feel and to help prevent bottoming out but unless your going with a Coilover setup on all 4 corners the ride between a factory shock that has adequate travel left after lowering and a drop shock will not be very noticable.
Here is what i plan to go with:
Mcgaughys economy kit w/ shorter endlinks and track bar relocator(lowering springs front and rear) ~ $450
Helper bags for the rear coils to help prevent bottoming out when towing ~ $100
Sorry for writing a book but im in the same boat you are so i figured my input would help you out.
Old 10-27-2011, 10:14 PM
5.7ram's Avatar
Vehicle: 2010
I for sure do not want the truck to bottom out , but for year's i have always heard BellTech is the Ferrari of suspension for truck's...
Now that you mention KW's , i wil contact them and see whats up. I would love to have a full coilover kit...
Old 01-05-2012, 08:56 PM
25bduse 25bduse is offline
Vehicle: 2011 Dodge Ram Quad Hemi
Color: Rugged Brown
25bduse is on a distinguished road
What supporting mods are needed with the bell tech 2/4
Old 01-15-2012, 12:36 PM
thmupr thmupr is offline
Vehicle: 2014 Ram Sport
Rep:12
thmupr is on a distinguished road
Just curious.. Is the Mcgaughys kit a 2"/4" or is it like the Ground Force, 1.75/3? I love the way the GF kit looks, but damn it's expensive for what it contains! I too am going drop my crewcab very soon, just gotta find the right kit for the $$$.
Old 01-15-2012, 10:36 PM
Stuck2theAxles's Avatar
Stuck2theAxles Stuck2theAxles is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT BigHorn
Color: Gray
Rep:108
Stuck2theAxles will become famous soon enoughStuck2theAxles will become famous soon enough
The lowest you can go is to buy my kit and buy belltech SP shocks haha and thats the ultimate set up, ive already done the testing now you get to enjoy
2011 CCSB Sport 2WD - McGaughys, FOOSE , shaved clean and newly added DIABLO SPORT !!
2012 CCSB Lone Star 4WD - McGaughys , KMC, shaved clean
2012 CC 2500 Cummins - Thuren, Fox , H&S w deletes upstairs and down
Old 01-16-2012, 06:17 PM
5.7ram's Avatar
Vehicle: 2010
B.T suspension is on it's way..... I can't wait. Wheels and tires are ready to slap on...
Old 07-30-2012, 04:23 AM
jorhfo jorhfo is offline
Vehicle: 2011 dodge ram 1500 5.7
jorhfo is on a distinguished road
Trying to put a front end 1 3/8 sway bar on from suspension connection. The hardware they sent with the sway bar looked like a 5 year old made it. The sway bar was to long and would not connect with the control arms. Has anyone out there had this problem? I'm thinking about retrying to put on the new sway bar using the stock hardware, being that the stock hardware actually swivels. Any help on this would be greatly appreciated.
Old 07-30-2012, 04:47 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I also bought an adjustable Sphons panhard bar. The kit already comes with shorter sway bar endlinks.
excessive tire wear on front tires Bamboo Dodge Ram Wheels And Tires 5 10-20-2011 07:50 AM
2009 TRX 4x4 Suspension Question Greenscape 2009 Dodge Ram Forum 2 12-14-2009 06:26 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
Lowering tech question... curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 11-06-2009 09:39 AM
Front Suspension Question 03 Hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-25-2009 09:55 PM
