just a question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 07-05-2012, 11:00 AM
gotmud's Avatar
gotmud gotmud is offline
Vehicle: 1996 dodge ram
gotmud is on a distinguished road
Default just a question
good morning all i have a 1996 1500 4x4 318 auto reg cab short box with a 2 inch helper spring and 35inch BFG muds now im trying to tow a 16 foot inclosed trailer and as soon as a hit 60 kms the trailer starts to sway side to side really bad any ideals why and what i can do to help it thanx
its all fun and games till someone losses an oil pan
Old 07-05-2012, 09:51 PM
Trouble's Avatar
Trouble Trouble is offline
Vehicle: 1997 ram 1500
Color: red over silver
Trouble is on a distinguished road
Is the trailer empty or loaded?
Old 07-06-2012, 09:13 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Tires in good shape, springs as well? Most of the time if pressure is in tires and tires themselves are good shape and springs are good. A lot of trailer sway is caused by haveing to mutch weight at the end of the trailer. If you have a small single axel and that happens it get scarry fast. Can't imag abigger tandem doing it.
Old 07-06-2012, 12:03 PM
ramfam's Avatar
Rep:21
The best thing to do if possable is try to equil out weight in trailer so that its evenly distributed over the bridge of the truck. In this case it would be the space between axl of truck and axl of trailer. If you can load trailer so both units are as level as possable to each other more of the weight is even over all axls. This will improve control and aid in stopping. Remember unless you have electric brakes on trailer all of your stopping power is up to front brakes. If there's to mutch at front of trailer you take weight off front causeing front end to loose brake power to ground and cause steering float. And to far back you unlaod rear axl so when you hit bumps or un even pavement trailer will start to bounce and truck will loose contatct with road causeing sway. Hope link uploads and it helps. http://www.etrailer.com/faq-trailertowtips.aspx
Old 07-06-2012, 08:04 PM
gotmud's Avatar
thanx for all the replys all four tires are new on the trailer and i had to have my father in law come with his new f250 diesel to tow it the rest of the way and he had no problems doing 100 kms down the hwy and nothing was changed in the trailer just unhooked from my truck then put on his and yes the trailer and my truck are set up for electric brakes and they work, when i put the trailer on my truck it does not sit the rear of my truck down much more then an inch
Old 07-06-2012, 10:58 PM
ramfam's Avatar
Rep:21
Is father in laws truck a duly? Sometimes that can help trailer stability do to the wider footprint of truck. Well glad you got where it needed to be safely.
Old 07-07-2012, 08:19 PM
gotmud's Avatar
yup got the trailer back all is good and no his truck is not a duly
Old 07-07-2012, 08:30 PM
Rep:2964
i bet his hitch is at a better height for the trailer
it sometimes only takes an inch or 2
Old 07-07-2012, 09:57 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
Take a tape measure and measure the height of the tougue to the ground on both vehicles, (as said above that might be the difference) and make sure that yours matches his height.
