Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-05-2012, 12:09 PM
gotmud's Avatar
gotmud gotmud is offline
Vehicle: 1996 dodge ram
gotmud is on a distinguished road
Default oil presure sending unit
hello i have a question after about an hour of driving i lose my oil presure if i turn the truck off and waite few mins it comes back and is good to go for an hour again now my question is does the sending unit just work the light and gauge or does the engine actually lose oil presure ? thanx
its all fun and games till someone losses an oil pan
Old 07-05-2012, 01:47 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Well from what I can tell of them it just works dash. Not to say you could loose pressure the only way to tell it isT in a micanical gadge and test it that way. But on up side pumps arnt to expencive and fairly easy.
Old 07-14-2012, 01:55 PM
spillage spillage is offline
Vehicle: 1998 RAM 1500 4x4 Man SWB
Trim Level: R1AZ - Sport
spillage is on a distinguished road
The oil pump itself is a simple mechanical device that essentially is working or it's not... I can't think if a failure mode for the oil pump that would be intermittent.
A worn oil pump will exhibit signs like slow to raise oil pressure on start-up, and low operating pressure... to have no pressure, the pump would have totally failed, or you have a big puddle on the ground due to a major external leak and an empty oil pan.
Pressure senders on the other hand do deteriorate over time due to heat exposure.
It is not unusual for them to weep oil around the plastic insert when old.
~ Bryan ~
Old 07-15-2012, 07:23 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Where is the oil sending unit located on these 02' 5.9's ???
Old 07-15-2012, 09:01 PM
colwell707 colwell707 is offline
Vehicle: 1999 Dodge Ram 1500 4*4 5spd
Color: grey
colwell707 is on a distinguished road
Ive gone through 4 of these POS sending units. Including 3 from mopar. Checked the load on the guage and its good. Checked pressure with a manual guage and its solid. But everytime rpm drops below 1500 it drops to zero and the check guages light comes on and it dings at me. I'm tired of this. So does anyone know what size resistor to put in the pig tail for the sending unit so I can install a manual guage in the cab?
Old 07-15-2012, 09:07 PM
Color: grey
It's located on the very back of the block to the right of the distributor. It can be reached from the bottom over the top of the transmission
Old 07-17-2012, 10:46 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Rep:194
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
I would put a t in where the sensor goes in the block and add a mechanical gage to it for a steady accurate reading.
Old 07-18-2012, 02:33 AM
Color: grey
I would like to do that but the check guages light and buzzer would still come on. So I would like to do away with that with putting a resistor in the line. Remove the sending unit and put in a manual guage in the cab. Problem is i dont know what size resistor to put in. So i was hoping someone had done this before and could tell me what size resistor to install.
Old 07-18-2012, 11:59 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Most I have herd t in and put old sensor in till there sure if its pump or sensor
Old 07-20-2012, 02:44 AM
Color: grey
The motor is all new including the oil pump and i checked it with a snap on manual guage. its good. Just neeed to know what size resistor to put on the sendor unit pig tail. so i can elminate the sending unit and put a manual guage in the cab.
