Old 07-06-2012, 04:15 PM
Pattipileloader's Avatar
Pattipileloader Pattipileloader is offline
Vehicle: 1991 Dodge Ram 150
Rep:71
Pattipileloader will become famous soon enough
Default Rims on a D150 1991
Im having some choosing troubles. I've been thinking about geting some really nice rims for my D150 after I paint it, and I'm thinking of doing either a chrome setting (since the trucks has already so much chrome in it) matt black rims or white rims. And they have to follow budget (darn expensive to import rims from the US to Iceland, any thoughts lads?
Dodge Ram 150 1991 3.9 petrol RWD ''Jötunn''
Dodge Ram 1500 1996 5.2 Magnum V8 4wd ''Týr''
Old 07-06-2012, 05:37 PM
Rep:2616
I believe that your Rims have
Lug Pattern
Metric: 5 X 139.7
Standard: 5 X 5.5
1/2" stud size, 12.7000 mm
77.8 hub center bore, this is stock size, snug fit on your hubs, takes the weight off the Lug Studs
diameter is 15"
width is either 6 or 7"
possible choices for you
DODGE RAM 1/2 TON TRUCK 2 & 4WD 1994-01 Metric: 5 X 139.7
Standard: 5 X 5.5 1/2-RH 77.8
DODGE RAM 1/2 TON TRUCK 2WD, 4WD 1994-01 Metric: 5 X 139.7
Standard: 5 X 5.5 16 X 7 1/2-RH 77.8
DODGE RAM VAN 1985-03 Metric: 5 X 139.7
DODGE RAM VAN 1985-96 Metric: 5 X 139.7
Standard: 5 X 5.5 15 X 7 1/2-RH 77.8
DODGE RAMCHARGER 1979-83 Metric: 5 X 139.7
Standard: 5 X 5.5 15 X 6.5 1/2-RH 77.8
referenced from http://www.roadkillcustoms.com/hot-r...+TRUCK#Matches
so no matter what color or finish that you want to go with, if the rims will fit the above vehicles, your good to go
gives a bit of a larger selection
Old 07-06-2012, 05:54 PM
Vehicle: N/A
Rep:1045
Well what kind of look are you aiming for? Street truck or a off road look?
Old 07-06-2012, 08:50 PM
Rep:71
well, i think ill go with a street look, since i already have another dodge I'm going too mod for offroading
Old 07-07-2012, 12:53 AM
Vehicle: N/A
Rep:1045
Here's where I've been looking at wheels. I searched under the second Gen rams, but the bolt patterns are the same. I think a 5 spoke would set a street look for it well.
Best prices I've seen at least
http://www.andysautosport.com/custom..._2001_ram.html
Old 07-19-2012, 04:20 PM
does anyone know the hub bore of a 2012 Ram 1500 4x4?
Is it 77.8mm as well?
The wheels/rims Im getting are 78.1mm center bore
Will I have any issues on vibration, etc?
I know the lugs are lug centric, but I have had wheels in the past that did not come with the hub centric rings and I have vibrations.
Not on all wheels but a set that drove me crazy...dollars later I was told it needed hub rings and that solved the problem
Thanks
