Starting problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-06-2012, 07:18 PM
Rtrrckt Rtrrckt is offline
Vehicle: 2001 Dodge Ram 2500
Color: forrest green
Rtrrckt is on a distinguished road
Default Starting problems
My truck won't start. I have checked battery post, battery cables, batteries, starter, starter relay and clutch pedal switch all are good I am left with the ignition switch. Does anyone have any other suggestions as to what else I might need to check?
Old 07-07-2012, 12:59 AM
NCDEVILDOG's Avatar
NCDEVILDOG NCDEVILDOG is offline
NCDEVILDOG is on a distinguished road
Send a message via Yahoo to NCDEVILDOG
By checking do you mean just looking at them? Have you checked the voltage of your battery with a multimeter? Sometimes your battery can put out full voltage, but then when a load(your vehicle starting) is put on it, the battery won't have enough amperage to actually start the vehicle.
semper fi to all my brothers out there!
Old 07-07-2012, 08:50 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Let us know how you make out and please keep us updated.....
Old 07-08-2012, 02:50 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
have you looked into ASD relay? or if lift pump its self is primeing or if crank position sensor is good. and i do think that cummins has one.
Old 07-19-2012, 04:10 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by ramfam View Post
. . . or if crank position sensor is good. and i do think that cummins has one.
It does & it's a bear to get to -- it's in the middle portion of the engine as opposed to front or rear as on other diesel engines. Crank Position Sensor on mine just quit without warning several years ago -- my son drove the truck for a while, next morning it wouldn't start & he thought it was his fault -- it wasn't, the CPS just died. Oh, the marvels of modern electronics
The other possibility I've referred to in several threads -- the Bosch VP44 injector pump WILL fail without warning, Dodge dealers only put another rebuilt stock pump on & the ONLY way to solve that problem is to get the Frieghtliner "Sprinter" van VP44 upgrade from an aftermarket shop -- I got mine from Blue Chip Diesel in New Hampshire.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-19-2012, 04:25 PM
Rep:57
An update on the crank position sensor possibility -- I just happened across this in a tech article: "Code 1690 or 336 indicates a signal issue with the Crankshaft Position Sensor."
