Lengthy Review: S&B Cold Air Intake 75-5064 [2009-2012 Ram 1500 5.7L Hemi] - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-19-2012, 02:19 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
It's called an restriction to increase of velocity on the downstream side....same principal used in my field of work. At my refinery every pumps suction is smaller before it enters the impellers of the pump creating a restriction at point A (suction)then opening it on point B (discharge) making the velocity greater as it leaves.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 07-19-2012, 05:37 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
the whale schlong design .
even BFI intakes are like that, HUGE filters and pipe then reduced to the TB to match up- if not then your TB will have to be 6+ inches to match with the intake tube. i think our TB's are 3 inches in dia. so no matter what, a bigger intake will have to be reduced
Old 07-19-2012, 08:04 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Whale schlong lmao.
Ok big hose goes on the filter and smaller hose connects tb to the tube.
-Pat-
Old 07-19-2012, 11:08 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
That seems to make sense,,,
I can't complain much about the Airaid I had. (yep, sold it, back to OEM now)
It was OK, but nothing that seemed to make much difference other than noise. (That, and a real PITA when I would occaisionally rinse out the engine compartment)
I had this: http://www.airaid.com/ProductDetail....ductID=300-237
Its no different than this with a tube:
http://www.airaid.com/ProductDetail....ductID=300-236
The tube diameter at the filter box with either is 'OEM'. Just doesn't seem 'natural' with a big azz filter! LOL!!!
Perhaps Airaid should just sell the tube itself along with a drop in, like they do for OTHER trucks! (or did testing show no benefit? )
Anywho, its nice to see something new for the 4th gens from S + B!!!l
Old 07-20-2012, 08:37 AM
BlackHemI's Avatar
Rep:296
those air raid intakes are huge!!! you really didnt feel a difference? they look like a nice kit but expensive!!!
-Pat-
Old 07-20-2012, 08:54 AM
Grubrunner's Avatar
Rep:3883
I actually saw an Airaid installed in a 4th Gen a few weeks back. It looked really nice but I'm just not a fan of the open/unboxed design intakes.
What was the difference in the tube's diameter at the box's exit from your Airaid compared to the OEM tube? The one I saw actually looked a tad smaller compared to the OEM accordian-type tube, correct?
Grub out!
Grubrunner's Avatar
Rep:3883
There you have it....
What do you do?
Grub out!
Old 07-20-2012, 02:03 PM
Color: Hot pink
Rep:135
Fit was great, easy to install,,, looked good, but the open design didn't appeal to me much. Hoped it would seal to the underside of the hood... Some folks say their's do, but mine didn't,,, Gasket barely kissed the hood insulation in one corner only,,,Data logging w/my cortex indicated a quick rise in IAT's when stopped,,, Cooled down quick when moving, but no distinct advantage in temps vs. OEM,,, actually worse in stop and go conditions, which I do a lot of,,,
I sold it last fall, and I can't say I noticed / remembered any smaller pipe inlet ID in the Airaid than the OEM. At the airbox, the inside diameter of the OEM pipe and the hump hose used with the Airaid pipe are identical.
No noticable difference in either end of the airbox hump hose, so l'm under the impression they were 'very close' to each other.
TB end of Airaid pipe was bigger than the TB. Hump hose was 100% 'directional' and you could only fit/install it one way,,,
Diameters do affect flow and velocity. Velocity can be beneficial, and so can 'ball's to the wall' big azz intakes,,,, but,,, I tend to believe certain qualities are good for certain applications.
Matching a certain quality to it's corresponding application is key.
Kinda like the 3 bears and Goldilocks! LOL!!!!
Old 07-27-2012, 01:28 PM
immokalee98's Avatar
immokalee98 immokalee98 is offline
Color: Black on Black
Rep:16
immokalee98 is on a distinguished road
Hey Grub, did you install the intake before or after the exhaust change?
Old 08-07-2012, 06:22 PM
Grubrunner's Avatar
Rep:3883
sorry, just saw your question.
The Magnaflow 16869 and 10778 combo was installed well prior to the S&B CAI.
The Magnaflow combo was one of my very fist mods back in January a few short weeks prior to the truck's purchase; when the truck had less than 500-miles on the clock. I then did [re-piped] the crimped OEM pipe under the transmission about two weeks later.
The S&B CAI was installed just this past month.
I'm still testing the MPG gains on the S&B CAI and will give an update real soon with my most lengthy out-a-state trip only days away.
Grub out!
