Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-08-2012, 01:46 PM
RamNJ's Avatar
RamNJ RamNJ is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: Hemi
RamNJ is on a distinguished road
Default Left side tire wear
Hey folks I started to notice my left driver side front tire is wearing out on the outside wall. Usually when im turning to the right I hear a knocking noise of some sort but it happens once only turning. Has anyone else have this problem? Any help would be appreciated.
Old 07-10-2012, 12:30 AM
H3E4M5I H3E4M5I is offline
Vehicle: 2007 Ram 1500
H3E4M5I is on a distinguished road
do you have a pull or wander? the noise could be a bad wheel bearing but thats got nothing to do with the alignment. but you can check the steering componets yourself with a bottle jack, pry bar and the wife.
put the bottle jack under the lower control arm close but not directly underneath the ball joint. jack it up enough to fit the pry bar under the tire. Have the ole lady pry up on it and look for loose componets. check the tie rods by having her shake the tires from side to side.
keep an eye on the bearing too, you should feel the same amount of play vertically as well as horizontally if the bearing is the culprit. but sounds as if you have a ball joint out.
Old 07-10-2012, 12:05 PM
RamNJ's Avatar
Trim Level: Hemi
Yea it pulls a bit when turning. I was thinking the same it could be the wheel bearing. I give it a try with the bottle jack,pry bar and the wife. If its what you said then it def needs to get changed out. I appreciate your help brother.
Old 07-15-2012, 02:00 PM
Big Dog 2008 Big Dog 2008 is offline
Vehicle: 2008 dodge ram
Trim Level: lariat
Big Dog 2008 is on a distinguished road
Yo folks I have a similar tire wear issue on the left front tire. I noticed that also my struts/shocks have alot of oily residue on the springs, mostly on the left side. My lower control arm squalls like crazy when i hit highs and lows inthe road. Mybest guess is control arm bushing failure and struts
Old 07-15-2012, 02:03 PM
Trim Level: lariat
More info The issue is on my 06 1500 with 60k
Old 08-05-2012, 03:22 PM
puzzell puzzell is offline
Color: red
puzzell is on a distinguished road
i had the same problem and it ended up to be the wheel bearing hope this helps
