Spindles? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-08-2012, 11:11 PM
MorePwr's Avatar
MorePwr MorePwr is offline
Vehicle: 2011 Ram Crew Sport
Color: Deep Water Blue Pearl Coat
Rep:50
MorePwr will become famous soon enough
Default Spindles?
I am guessing most of you are using the spring kits because they are cheaper, but how much has the ride changed?
I am old school lowrider, with several S-10s and B-Body GMs under my belt. The trucks always had spindles or lower control arms to start with then combined with springs for deeper drops. The spindle helps so much when it comes to alignments and tire wear.
So how come you aren't using spindle kits?
Sean
McGaughy's|Spohn
Old 07-08-2012, 11:14 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Think for some it comes down to price.
For me i would do spindles over springs no doubt for ease of alignment. In my case i have both 2" spindles and 2" springs but im a 3G. My issue was mostly clearing 17's due to the spindle nut but a little trimming took care of that.
Old 07-08-2012, 11:29 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
If your budget allows, McGaughy's spindles are the way to go. Not only will they retain a factory ride, but they also give you room to grow if you decide to go lower in the future. I only wish McGaughy's offered their kits with upgraded shocks.
Old 07-08-2012, 11:36 PM
Rep:3347
Anyone know for sure if the McG's 3rd gen spindles will fit the 4th gens? I thought there was a difference between the two and nobody has made a set for the 4th gens.
Old 07-08-2012, 11:51 PM
Rep:69
McGaughy's lists the same part# for the spindles from 02-11. Their spindle drop kits are the same though from 09-12, so I'm guessing they just havent updated the site yet.
Old 08-04-2012, 01:43 PM
MorePwr's Avatar
Rep:50
So for those using spindles... If anybody has.... is the rear spring rate of McGaughys too soft? I want the stance dropped, ride mostly retained and load capability close. The future holds a 21ft boat....and several home improvement projects.
I know there are bag systems to assist the load, but that is another expense...I am looking at the 2/4 kits.
Sean
McGaughy's|Spohn
Old 08-05-2012, 05:41 PM
Rep:69
The rear spring rates are similar, but the distance between the axle and bumpstops will be significantly shorter. Because of this, I would recommend bags out back to help with the boat in tow.
Old 08-06-2012, 10:28 PM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
Don't forget that the spindle kit pushes the front tire out, wider track. I do not like this aspect of the dodge spindle kits. I'll stay with springs.
Old 08-07-2012, 04:10 PM
Zevox's Avatar
Zevox Zevox is offline
Vehicle: 2014 Ford Mustang
Trim Level: GT
Color: Race Red
Zevox is on a distinguished road
The McGaughy's spind kit comes with different bump stops.
I don't tow with mine so I can't really give insight(they decided not to order a hitch from the factory but yay I've got remote start -_-) but the ride with stock shocks is fine, obviously stiffer but not bad. They sell the rear shocks from the Belltech kit and I was considering buying those. Also, the McGaughy's kit has a track bar relocator unlike the Belltech kit so it pushes the rear end out to one side, from what I've heard.
While the spindles do push your front end out a little bit, it's not that noticeable unless you really *look* at it. Luckily the little bit of offset the spindles provide helps to clear some SRT10 wheels since they take such a wide tire.
Old 08-09-2012, 04:56 AM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
this is the mcG spindle kit with roughly 1000 lb in the bed. You probably won't need airbags.
The only things I do not like about the spindles are the fact that they are made of uncoated steel which = weight and rust, and the fact that they increase the front track width. Otherwise, the ride quality is great, and no alignment issues after 5,000 mi.
07 rclb cummins. Efi live by silver bullet tuning
