Old 07-09-2012, 11:16 AM
mos98dodg mos98dodg is offline
Vehicle: 98 Ram 1500
Color: Silver/Gray
mos98dodg is on a distinguished road
Cool 4x4 Actuator
When my 4w drive became inop and front axle did not engage, I replace the actuator and 4w then worked. Just recently my 4wheel is again not engaging, the actuator is still new but loose. Any one know what could be problem?
Mos98dodg
Old 07-11-2012, 10:33 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
make sure your vacuum lines are still hooked up and see if there are any holes in them. maybe try to tighten the actuator up again also
Old 07-16-2012, 11:50 AM
Color: Silver/Gray
Hey thanks for the info, I took trk to mechanic and that's what it is, he said no vacuum so to check my lines, I'm trying to trace now. Thks for your help.
Mo
Rio Rancho, NM
Old 07-16-2012, 10:28 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Take a look at the drivers side of the tranny crossmember, for two tubes, common disconnect area, I clamped mine with zipties, no more grief.
Old 08-28-2012, 03:02 PM
sth7344 sth7344 is offline
Vehicle: 1999 Dodge Ram 1500 sport
sth7344 is on a distinguished road
Just woundering what you found. I am having the same problem with mine. Trying to trace the vacuum lines out but there is so much mud under the truck i keep loosing them
