Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-09-2012, 01:27 PM
mjcibor mjcibor is offline
Vehicle: 2006 Dodge Ram 1500 SLT
mjcibor is on a distinguished road
Default Brake Pads/Rotors Question
After replacing my pads and rotors while the truck was still on jackstands, when I bolted the wheel back on there wa some play between the wheel and the rotor. The guy at NAPA told me to pump the pedal which I did and it tightened up, no play, which you would expect when the pads are hard against the rotor. Does this sound normal? Thanks.
Old 07-17-2012, 10:46 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
No.
The tire/wheel should spin freely until the brakes are pumped a couple times, but not move in & out.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-27-2012, 01:39 AM
bighook bighook is offline
Vehicle: 2007 RAM 2500HD 4x4 Reg Cab
bighook is on a distinguished road
Could be other components that are the cause of looseness - worn hub/wheel bearings or ball joints.
Old 07-27-2012, 11:46 AM
clbresnyan's Avatar
clbresnyan clbresnyan is offline
Vehicle: 2005 Dodge Ram 1500 4x4
clbresnyan is on a distinguished road
Your rim should snug right up to the rotor and be tight there should be no play between them.
