Old 07-09-2012, 04:53 PM
Daletec Daletec is offline
Vehicle: 2001 Dodge Ram
Trim Level: SLT Laramie
Color: Burgundy
Daletec is on a distinguished road
Default 2001 5.9 with 46RE shift into 2nd
I am completely new to MOPAR, so please bear with me.
I have a 2001 1500 4x4 with the 5.9 Magnum, 231 HD Transfer Case and the 46RE transmission with 4.10 diff. gears. When I accelerate hard, the tranny acts like it's shifting into 2nd, only to remain in 2nd, then progresses through the gears. The behavior is the same with OD turned off. Please point me in the right direction. It's almost like a "fake" shift. TPS or some other sensor is all I can think it to be, but I'd like to tap the knowledge of those with more experience on these.
Old 07-09-2012, 04:58 PM
RamSport1996's Avatar
RamSport1996 RamSport1996 is offline
Vehicle: 1999 Dodge Ram 1500 Sport
Trim Level: sport
Rep:13
RamSport1996 is on a distinguished road
Could be the front band inside the transmission... What tends to happen is the front band snaps off and will sit in the transmission pan. Same thing happened to me.... Did you hear any grinding noise coming from your trans lately when in drive??
Old 07-09-2012, 06:56 PM
Color: Burgundy
No grinding when driving down the road, it's a sort of slip, almost and it otherwise behaves normally. I don't drive it hard, I just noticed when testing a bit. I do know that I plan on performing a maintenance, as I don't know the history, and I read about changing the valve body and removal of the ball check valve(bad point of failure), to prevent the draining of the torque converter. Still got tons of reading to do. I have also looked into replacing the intake manifold pan.
Old 07-09-2012, 08:22 PM
DodgeGuy85's Avatar
DodgeGuy85 DodgeGuy85 is offline
Vehicle: 1996 ram 2500 4X4
Color: Blue
DodgeGuy85 is on a distinguished road
I have a 96' 2500 5.9 4x4 and had tranny issues as well and what fixed mine was I changed to Castrol synthetic ATF fluid,new filter and new shift solenoid.If you're not sure what that is,when you take off you're trans pan you'll see a wire harness that is plugged into this round metal piece should be passenger side of tranny when looking at it from underneath, looks just like an old starter solenoid in a way. Disconnect the wiring at the plug on side and pull the solenoid straight down it just pops right in there. Try that first if and when you change your fluid and filter. They tend too go bad and start making the tranny shift weird and erratic. After doing this with my truck I've had no more issues and it's been close to 6 months now...Good luck with what you find...p.s I found the shift solenoid at AutoZone I believe it's made by Duralast for $135.00 It's a little pricy but will hopefully save you on a rebuild...
