Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 06-28-2012, 09:49 PM
Brownbear Brownbear is offline
Vehicle: 2011 Ram
Trim Level: BigHorn
Color: Brown
Brownbear is on a distinguished road
Default Rear diff fluid
I drained rear diff and about 3 quarts came out. With lifting the rear wheel 4 inches to angle the axle I was only to get about 2 and a 1/3 quarts in. Why did the factory overfill so much? And should I keep tilting the axle until I can get 3 qts in. 2012 Ram 1500 with limited slip
Old 07-10-2012, 09:01 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
capacity is 4.6 pints which is just about 2 & 1/3 qts. close it up. what size hex socket did you use?
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-10-2012, 09:21 PM
Rep:19
and.... for LSD's the owner manual says to add 4oz of the Mopar LSD additive.
