No power, flashing red light.arrgh - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 07-09-2012, 10:10 PM
echofoxtrot echofoxtrot is offline
Vehicle: 2002 Dodge Ram
Color: green
echofoxtrot is on a distinguished road
Default No power, flashing red light.arrgh
Have a 2002 Dodge Ram 1500 slt quad cab - Wasn't driven for a while and needed a boost to get started. Let it idle about 20 minutes and drove for about 10 miles with no problem.
Then the radio started to cut out and the headlights/dashlights dimmed then went out. A moment later the truck died with a little flashing red light on the dash.
Boosted the truck again, left idle for another 15 minutes. Turned it off and wouldn't start again.
Should I assume the battery is the culprit or maybe the alternator?
Thanks for any help!!
Old 07-09-2012, 11:15 PM
H3E4M5I H3E4M5I is offline
Vehicle: 2007 Ram 1500
H3E4M5I is on a distinguished road
i'd do both. If you have a volt meter, check the voltage of the battery and watch the drain. a good battery should read above 12.4 and shouldnt fall rapidly once you check it. if it reads any lower than 12, replace it.
to check the alternator, it needs to be running, take either the positive or negative pick, put it on the silver case of the alternator and the other pick on the positive side of the battery, should read about 14.6.
if you dont have a meter, just start with the battery. if it keeps giving you an attitude then its probably the alternator as well.
Old 07-10-2012, 06:41 AM
Color: green
Sounds good, i'll give it a try and let ya know.
Old 07-10-2012, 11:34 AM
sounds good to me!
