Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Place your Ad Here!
Old 07-10-2012, 09:50 AM
Young Gun Young Gun is offline
Vehicle: 1995 Dodge Cummins
Color: Forest Green
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
Young Gun is on a distinguished road
Question What to do to my truck
Hello, i am 17 and have had my 1995 dodge 5.9L cummins for about 7 months now. since i got it i have:
-Turned the p-pump up all the way
-put guages in it(trans temp, boost, and ext. temp)
-put a used, stock,transmission in it(as mine blew up on me)
-put a used, stock, turbo on it
-put a toolbox in it and attached two 5tf. cb antennas and put a cb in
Haven't done much, What i am wondering now is what is the best way to get more power/better performance out of it easily.
i was thinking like a cold air intake maybe?
i am pretty smart mechanically wise but am no mechanic.
Thanks,
TJ
Old 07-10-2012, 07:09 PM
Rep:3337
Check out a high ram intake, a cold air intake, a smarty programmer (if they have something for a '95), and look at a 4" or bigger turbo-back exhaust
Old 07-19-2012, 12:31 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
. . . smarty programmer (if they have something for a '95) . . .
Electronic controls didn't come out 'till the '98 1/2 24-valve models (I have one) -- the earlier 12-valve engines use a straight mechanical fuel system. And that's a good thing, considering the fact that it costs over $2000 to get a good (computerized) injection pump for the 1998.5-2001 models. The 12-valve engines don't make as much power, but they don't just die on you from an electronics problem either.
. . . i am 17 and have had my 1995 dodge 5.9L cummins for about 7 months now. since i got it i have:
You can get the Edge boost elbow for $27 which makes the boost come in sooner & allows it to go a bit higher too -- delays the wastegate opening -- you need more air to go with the additional fuel & smoke out the exhaust is wasted power & fuel mileage both.
The neck on the intake manifold can be replaced with aftermarket (the high ram intake mentioned) which will raise the boost too + it smooths out the flow from the intercooler hose into the intake manifold. And if the factory airbox isn't already "cold air intake" (mine is), getting an aftermarket unit is good & even if the box is ducted to the outside, a K&N air filter always improves airflow -- I just replaced the stock paper filter with a K&N.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
