Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 07-10-2012, 01:58 PM
lirex3 lirex3 is offline
lirex3 is on a distinguished road
Default Does Dodge truck suspensions suck
my 2010 ram 1500 bighorn makes noises when I turn the steering wheel left to right. I was warned by a couple friends to stay away from Dodge, they told me suspensions suck. Go either ford or chevy. Well I took my truck in to the dealer they said its a truck and thats normal. You tell me a close to $50,000 truck with just over 15,000 has suspension problems? I had a jeep grand cherokee larado and suspension on that was the worst vehicle I have ever driven.
Old 07-10-2012, 02:33 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
That's a cool story.
Generally, noise isn't normal from the suspension or steering system. Perhaps you could post a video of the noise, or a better description, so that others could comment as to the source of it.
Old 07-10-2012, 02:37 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
No suspension noise from mine...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 07-13-2012, 11:27 AM
I will post a Vid later... When I turn the steering wheel left or right I get a really nice sounding thud. Something has play under there. beleave me I wanted to choke the service advisors at the dealership I went to when they told me thats normal. I called into Dodge and complained they told me to try out another dealer. Did not mention the dealer had my truck for 11 days to finally tell me thats normal.
Old 07-13-2012, 01:31 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Your friends - excuse me but - Don't know what the heck they're talking about.
coincidentally, I just got done working on the suspension of my RAM. After having owned a Ford PSD and a Chevy Duramax, I was really happy to see how good the build quality is on this Dodge RAM. The Chevy had the worst suspension of all three and the ford was about the same but not as beefy.
Besides, How many differences can there really be? springs are springs, A-arms are A-Arms, etc. The difference on the Chevy was the weak ball joints and pencil size tie rods.
Every single piece of the dodge suspension is built better than necessary. I can get you pictures at your request
Old 07-13-2012, 01:32 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
No noise here, 63k miles. Just normal PS pump noises. My F100 creaked badly(in the front) when it was on the road... My s10 also creaked a little(in the rear). Liked them both though this ram is by far the best.
Sean
Old 07-13-2012, 01:33 PM
snrusnak's Avatar
Rep:1385
Bikenut, keep in mind your truck is much more heavy duty than a 1500. Not that the 1500 isn't built well, just not as HD as the 2500.
Sean
Old 07-13-2012, 01:34 PM
Bikenut's Avatar
Rep:73
Oh, and those crappy Hub/wheel bearing combo things on the Chevy - pure Poo!
If I were in you situation, I'd get the front end up on stands and start looking for the culprit. Suspension components are pretty basic stuff. Once you find it, You can tell the service fool what to fix
Old 07-13-2012, 01:36 PM
Bikenut's Avatar
Rep:73
Damn sorry I'm speaking out of place again. ~ Well then, if it's an equal comparison between the big 3 1/2 tons and big 3 3/4 tons, the RAM should still be on top
Old 07-13-2012, 01:42 PM
snrusnak's Avatar
Rep:1385
I wasn't a big fan of this design either, not that I thought it was weaker or anything, but just sort of a PITA. Anytime you took the rotor off you were dealing with wheel bearings. I guess it does force you to repack or replace the bearings every time you do rotors, which is good since most people never touch the bearings. This design also raises cost on rotors so instead of say $50 for a new rotor you pay $150 for a new rotor/hub.
I got run off the road in my s10 once and went over a ~6" curb at about 55mph and was surprised to see no damage after it happened. I continued to work(~5 miles), then after work was driving home and got about half way(another 5 miles) and was hearing a clicking sound from that wheel. Just moments later the wheel started jerking to that side extremely hard for brief periods(like milliseconds). After it happened a couple times I pulled over. Had the truck towed home, and took the wheel off and I found that the hub must have cracked when I hit the curb then the stress from driving split it apart because the hub was split apart in a couple places and the bearings were jambed and crooked. I took it all off(barely was able to get the bearings off) and luckily the bearing had only barely scored the spindle, so it didn't need replacing. A new set of bearings and rotors/hubs and it was all good to go, but I was amazed at how that thick hub split apart.
Sean
