1997v 5.2l stalls at idle. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-10-2012, 05:49 PM
mmclaughlin mmclaughlin is offline
Vehicle: 1997 Dodge ram
mmclaughlin is on a distinguished road
Default 1997v 5.2l stalls at idle.
my 97 5.2 with 5 speed manual transmission stalls when at idle. I've cleaned the IAC and throttle body. And replaced TPS but doesnt seem to work. when driving randomly either the power cuts out or it won go past 3 rpm's. please help
Old 07-11-2012, 02:18 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
change out ur o2 sensor my 98 5.2 was doing the same thing and that fixed it
Old 10-15-2012, 12:59 PM
jdtonkin jdtonkin is offline
Vehicle: 2001 Dodge Ram
Trim Level: Base
Color: Green
jdtonkin is on a distinguished road
I had a similar behavior with my '01.
I ultimately figured out it was the Crankshaft Postion sensor. It's on the right rear of the engine at about the 1:00 position from the top. It's a pain to get to, but it can be done. You will need a 1/2" stubby wrench.
Do not buy a cheapo replacement. The initial one I bought only lasted a year. When I replaced that, I could see where the flywheel was rubbing against it.
Good Luck!
