Old 07-11-2012, 03:15 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
Default 5.9 cam in a 5.2
does anyone know if you can put a 5.9 cam in a 5.2 with little or no machining work
Old 07-14-2012, 07:10 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Yes, the cam for a 360 will fit in a 318 -- same block. You can put 360 heads on a 318 too, although the compression ratio will drop as the 360 heads have bigger combustion chambers.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
