Engine comp. wets during rainy conditions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-11-2012, 08:15 PM
olegriz olegriz is offline
Vehicle: 2000 Dodge B3500
Trim Level: base
olegriz is on a distinguished road
Cool Engine comp. wets during rainy conditions
We have a 2000 Dodge Ram 3500 R.V. class B that has intermittent door lock problems I
have chased down to wet conditions and I believe under the hood is the problem area.
When opened and with a fine spray of water on the windshield you can see water streaming to the engine comp. from the moulding that is located between the hood and the winsdhield. My question........is this flow a normal condition?
I have loosened the retainer screws of the moulding and inserted a sealant but there are contours and openings such as the hinge area that cannot be sealed.
Water seems to flow to so many areas in the engine compartment including the computer that I am concerned.
Your comments will be appreciated.
Old 07-11-2012, 10:13 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Is the rubber seal at the front of cowl missing?there should be two foam wedges on ether side of cowl with a pice of rubber seal like that of the door seal in middle. A lot of time they come loose and get well deleted.
