lift questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-12-2012, 01:18 PM
hockeybro43 hockeybro43 is offline
Vehicle: 2008 dodge ram
hockeybro43 is on a distinguished road
Default lift questions
i am buying a 2008 ram 1500. i want to either level the front and add a leaf in the back or do a small 2 in-3 in lift. which would be better body or suspension. honestly im just doing it for looks and minor off roading. i want to get the truck off the ground some for bigger tires without cause any front end problems. thanks for the advice.
Old 07-14-2012, 03:04 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by hockeybro43 View Post
i am buying a 2008 ram 1500. i want to either level the front and add a leaf in the back or do a small 2 in-3 in lift. which would be better body or suspension. . . .
Suspension. The additional spring travel will be beneficial & should give you the tire clearance you want -- as long as you don't go too crazy. I found that 33" tall tires was as tall as I could go on my '98 4x4 2500 which sits up much higher than a 1500 to begin with, so while I'd rather have 35's, the 33's do fine. After all, it's the clearance between the axles & the ground that matters, not how high the body is, 'cause when you start dragging the axles in the mud you'll get stuck.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
body lift, leveling kit, suspension lift
