Old 07-12-2012, 06:07 PM
bobbyhill bobbyhill is offline
Vehicle: 1999 dodge ram
Color: rihno lined
bobbyhill is on a distinguished road
Default nitrous questions having trouble finnding misc parts
alright first off i have searched around here found a little bit of common sense information and seems like most were dreamers that never went threw with it i hav e a nx main line wet kit nos purge kit bottle heater and blanket im looking for a throttle body spacer with a nitrous bung and also wandering what would be the best cam size to run my motors a rather fresh crate with 20k miles i have my piston rod combo just need some info and advice thanks
Old 07-12-2012, 10:07 PM
I push the skinny pedal
Rep:3277
You are probably going to have to tap your own tb spacer because I don't think anyone makes a nitrous plate for the magnum engines, not that I've seen anyways. What size shot are you planning to run? I would stick with the stock cam, get a stage or two colder plugs, and run a 100-150hp shot. You don't want to advance your timing with a nitous kit, in fact, you may want to pull some timing if you can and run a bigger shot with some high-grade fuel. If you don't already have one, pick up a nitrous pressure gauge to mount in the cab so you can monitor the bottle pressure, you want to be between 850 and 1050 when running with the NX solenoids
And please, in the future; use punctuation, that was just painful to read.
Kurtis
