Old 07-12-2012, 10:56 PM
fordge fordge is offline
Vehicle: 1996 dodge ram
Color: many
fordge is on a distinguished road
Default help with tie rod adjustment sleeve
got a 96 2wd 1500 ,had some jerky steering, upon inspection i notice thet the outer tie rod end is sliding around in the adjustment sleeve how do i fix this . anyone got ideas
Old 07-13-2012, 02:09 PM
RcsbHemi's Avatar
RcsbHemi RcsbHemi is offline
Vehicle: 2010 Ram Rcsb
Trim Level: SLT 4x4 3.92
Color: PDM Metallic Gray
Rep:32
RcsbHemi is on a distinguished road
If the tie rod is moving around in the sleeve either its not tight enough or the threads are damaged on the sleeve or the tie rod. First make sure it is tight enough and if you still have movement remove the tie rod and check everything out and replace anything with damaged threads. Remember to count the turns when removing and installing the tie rod so you dont mess up your alignment.
Mods: Magnaflow DOD14(resonator removed) line-x, tint, silverstars, tonno pro trifold tonneau, LED Licence plate and reverse bulbs, 2- 27w led fog lights behind grille. more to come........
Old 07-13-2012, 03:56 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Sounds like it needs replaced.
Sean
Old 07-19-2012, 12:08 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Second last post never guess with steering or brakes as they are kinda importend.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
