Old 07-14-2012, 05:57 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
panhead will become famous soon enoughpanhead will become famous soon enough
Default Ugh-- "Wobling"
Been trying to pin point this issue for awhile, kinda got it narrowed down by replacing some beat, worn out parts. Still haven't solved it. I own a 1996 Dodge Ram 2500, light duty 4x4. Happens between 66 and 68 MPH. It was worse before replacing the drum's. Had the tires balance twice. For some odd reason, I feel the kid that installed my tires did a half ass job. I got a very slightly bent wheel but was told that wouldn't be the issue. Several months ago I found out I have been running the transfer case dry. FYI, if you buy a highly used truck. Check all the fluids. Anyway, I don't think that could be the issue. Any input is welcome, its ****ing annoying having to deal with it.
Keep it Mopar, buy Mopar Parts.
I am completely disgusted every time I think about having to take a distributor cap off of one of these trucks -Screamintrashcan
Old 07-14-2012, 06:16 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
I've got a '98 2500 4x4 & I'm going to assume yours has a "track bar" up front like mine does -- the joint on the end of it wears out & the truck wants to "weave" going down the road in a straight line. It's not real bad, but it is irritating & the bad part is Dodge will only sell you the bar -- upwards of $300 last I checked. But if you can take it off & just replace the joint or have it done @ a local shop you'll solve that problem for a lot less $$$.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-14-2012, 06:20 PM
panhead's Avatar
Rep:103
Actually the track bar is tight, along with the front end. Gotten the track bar 2 years ago and its still tight. Its from TRW and only paid $150 for it.
Old 07-14-2012, 06:24 PM
Rep:57
Then I'd have to say bent wheel -- you were told it wouldn't be a problem but it is. I can't say if that's the only thing, but it's certainly a known variable that you can eliminate from the equation!
Old 07-15-2012, 08:11 AM
panhead's Avatar
Rep:103
I've honestly thought about getting new wheels.
Old 07-15-2012, 03:08 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you try rotating the tires/wheels to see if that helped?
Old 07-15-2012, 05:06 PM
panhead's Avatar
Rep:103
I did that to no avail. I did find out that I do have a clunking noise coming from the wheel so it maybe the wheel bearing. I will be checking it out sometime next week.
Old 07-15-2012, 05:24 PM
Rep:57
I don't know how much difference there is between your "light duty" '96 model & my "heavy duty" (8800 lb. gvw) '98 model, but I will tell you something I learned when changing front wheel bearings. When mine started "singing" on the left front I called the dealer real quick just to get an idea on wheel bearing price / availability & was told oh no, you can't buy just the bearings, the 4x4 front hubs are a "sealed" unit & you have to buy the whole thing -- for $850 !! Well, I might have been born @ night but it wasn't last night, just 4 bolts hold the hub assembly together & if you can bolt it together you can take it apart, so I took it apart.
Once I got the inner & outer bearings out & wiped 'em clean I called a Bearings, Inc. type place with the numbers stamped on the bearings to see if they had 'em -- yep, 3 of one which cost $13 in stock & 5 of the other which cost $15 in stock. Now I did have to buy a special impact socket for the king nut on the spindle & I also had to buy a big 3-jaw puller to take the assembly apart, but all-in-all I spent the better part of a day & around $100 to replace front wheel bearings -- instead of $850 per side for just the parts !!! Neither Dodge nor anybody else makes their own bearings, they use commonly available ones which a Bearings, Inc. type business should have all the time & don't cost very much, so don't let a dealer parts counter guy fool you with the "it's a sealed, non-serviceable unit" story !!
Old 07-15-2012, 05:27 PM
knappk6's Avatar
knappk6 knappk6 is offline
Vehicle: 2008 Dodge ram
Trim Level: Big Horn,MonsterMile
Rep:15
knappk6 is on a distinguished road
how about an unbalanced drive shaft?
35% tint on front, 2 JL 10W1 underseat, Kenwood KVT-514, Spectre CAI, Nitto Trail Grapplers 295/60R20, BILSTEIN 5100
Old 07-15-2012, 05:55 PM
panhead's Avatar
Rep:103
Not much a difference. My light duty is just basically a HD 1500 with 8 lug axles. Same axle and frame you'll find under a 1500. My hubs only require 3 bolts, the HD 2500's are 4. There is a very well known wheel bearing company. You're right about the dealer being expensive but I had replace the whole hub assembly on the pass side for $400 with a warranty. Company is call Timken, they also make bearings for rigs and the railroad. Only thing that's a pain in the ass is pounding out all 8 studs to remove the rotor and wheel hub/bearing assembly. When I did work on the front end, the drivers side wheel hub bearing actually looked original and I know it isn't going to last long with the roads being the way they are around here.
