Old 07-25-2012, 05:40 PM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:148
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
is 1 can enough to do all 4 insert pieces? how many coats did you put on?
Check my mod list.
Old 07-28-2012, 05:45 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
One can is enough yes. The more coats you put on the more build up and the easier it is to peel off. 4-6 coats is good. No less than 3. First coat needs to be a 50% transparency from the chrome to the plasti dip. So a light first coat. Then wait 5-8 minutes and do a second heavier coat. Then so on and so forth. It is a very sticky consistency so it is a little bit more forgiving with drips (:
Old 07-28-2012, 09:29 PM
Rep:148
ok im going to order a can. i saw a video on another thread where they did an entire car with with stuff and looked pretty good. thanks again jc for the info.
Check my mod list.
Old 08-07-2012, 01:03 AM
Rep:148
jc, how did you do your insert pieces? take the whole grille of and spray or take the inserts out and spray? thanks.
Check my mod list.
Old 08-07-2012, 02:44 AM
Rep:34
Well I took off the entire grille. Wiped it down a couple good times, and from there I masked off around the cross peaces. Leaving everything clipped together. Then sprayed it like that. I masked off around the bars a little on the outside leaving myself a natural break around all four sections. So when I went to peel the masking tape off I would peel the access plasty dip off with it. It will naturally break along the seem on the inside of the crosses. Make sure to get good 50% transparency on the first pass, and let it dry. The after that get a good 3-4 more coats on after that. Getting all the angles as the bars are kind of hard to get with the angles they are at.
Old 08-14-2012, 11:19 PM
AV8RAM's Avatar
AV8RAM AV8RAM is offline
Vehicle: 2011 Ram 1500 SLT
Color: Mineral Gray
AV8RAM is on a distinguished road
I wish I had seen this thread sooner I just bought a used chrome billet insert and pulled out my black honeycomb. If anyone is interested PM me
Old 08-19-2012, 07:05 PM
Rep:148
finally got the time and some decent wheather to do my grille inserts, looks SO much better with the black inserts. thanks jc for all the tips. i have been trying to post pics but everytime i try it says its to large or it doesnt load, maybe i will be able to figure it out and get some up here. AV8RAM i know somebody who is thinking about getting black inserts, how much you want?
Check my mod list.
Old 08-19-2012, 11:59 PM
AV8RAM's Avatar
Color: Mineral Gray
I really don't know what they are going for, but I was thinking around 75 plus shipping. I can't send/reply to a PM yet because I am too new to the forum but you can shoot me a text message if you like 617-852-6896.
Old 08-20-2012, 09:05 PM
Rep:148
i will let my buddy know and see if he is interested. if you dont here from me than he is not interested.
Check my mod list.
Old 08-20-2012, 10:32 PM
Rep:34
Kmark use photobucket. Upload the photoes to a created account on there, and then copy and paste each "IMG code" and paste them on here. It will post them (:
