Old 07-14-2012, 11:19 AM
ATLmopar ATLmopar is offline
Vehicle: 2004
Color: blk
ATLmopar is on a distinguished road
Default 4.7 problem
No cel are anything But every once in awhile ill pull in my yard put it in park and the truck slowly stalls then goed dead?? Any takers on this crazy problem. also I noticed even at 122k miles this truck has a tick in the morning when starting it up untill it gets warm.
Old 07-14-2012, 11:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The tick is pretty common/normal. Usually it's not too audible(can't hear it over the radio or anything), and goes away once warm after a few minutes.
As far as the stalling, I'd start by checking for vacuum leaks/cracked or dry rotted vacuum lines.
Sean
Old 07-20-2012, 11:30 PM
Vehicle: 2004
Color: blk
^ thanks man. Now If I can just et this gas mileage up from 13.2mpg
Old 07-21-2012, 09:28 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Sean is right on....the tick is normal for the 4.7....well actually, the hemi too for that matter except the hemi does it all the time, lol.
Wish I could help you with the stall issue. I don't really have anything good to offer except to say that I have read about quite a few erratic idle type issues with the third gen 4.7 trucks. If Sean's idea doesn't pan out you might want to think about the throttle position sensor or idle air control valve. They can actually cause problems without throwing a CEL.
And as for the MPG...that's close to par for a third gen, lol. I noticed a slight gain with a Magnaflow muffler. I MIGHT have averaged 14 mpg. I noticed a little increase with a Superchips programmer as well but I was running 93 octane in it with the performance tune so that might have been part of the reason for the increase. I found that the cost of 93 octane actually negated the marginal gain that I saw.
