Old 07-15-2012, 01:27 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
Default AirLift 1000 Installed
AirLift 1000 installed
step 1: Get off lazy ass
Jack truck up
You will need to remove the plastic cover that goes over the nipple on the top of bag. Squeeze out as much air as you can and fold into "hot dog" shape, then insert plastic cap back on nipple. Insert bag in lowest opening of coil
**NOTE** you can remove the coil and just push it down from the top of the coil. It would be much easier
Once inside coil, remove plastic cap and bag will take its original shape. The installation sheet I had didnt say anything about removing the coil and inserting bag. It said to insert bag, put protector cap on, then hook up air line. Doing it this way was a major PITA. But I got it. By the way, the tires and wheel wells will need to be removed to complete install. I tried many ways to get around it, just not happening.
This is all the room you have to put the hose clamp on hose, if you dont remove the coil. If you do it this way, you will need some small 90 needle nose pliers, no way around that either.
Then route your airlines, keeping them away from exhaust. I chose to have dual valves, that way I could lift the left side up more than the right, if need be, or vise versa. I drilled two holes and placed the valves in the usual spot. Yes I know they're crooked, and I dont care lol. If someone is close enough to my truck to notice that, they need to back back
Then I filled the bags with 5psi and checked for leaks, good to go
Install complete with 5psi in bags
And with 35psi in bags (maximum), not very noticeable but I gained about 1/2 inch I suppose
Havent driven the truck yet, but Im assuming Ill keep them around 10psi
MATT
Old 07-15-2012, 01:39 PM
h2oman's Avatar
h2oman h2oman is online now
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
Outstanding. How'd that boog taste?
333Half the beast
I used to be
Old 07-15-2012, 03:38 PM
Rep:420
Hahaha I'm not sure how they tasted lol
MATT
Old 07-15-2012, 05:11 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Yeah, I noticed a couple of the same issues that you did, so I just removed the coils. It made the job super easy. The coils were stupid easy to remove. I've pulled my 5000 pound travel trailer a couple of times on trips with no WDH so far, and they have worked as advertised. Excellent product for the money.
Old 07-16-2012, 05:13 PM
MXMagnum's Avatar
MXMagnum MXMagnum is offline
MXMagnum is on a distinguished road
Yep - easy to install. I left coils on, flattened bags and covered with soapy water to help slide in. With loaded 28 foot travel trailer, I run about 25 psi. Without trailer, run between 5 and 10 psi. Agree with TNC - excellent product for the money!!
Old 07-16-2012, 05:19 PM
Rep:420
Yup I haven't pulled anything yet, although I thought about putting the car up on the trailer today LOL, but I didnt. I did run around yesterday with 20 psi in bags w/o trailer and noticed it was a rougher ride. Today I had 10 psi and it felt real nice. I have to keep at least 10 psi in there because the gauge I got goes in increments of 10
MATT
Old 07-19-2012, 03:28 PM
Squatruck317 Squatruck317 is offline
Vehicle: Lots of Toys
Trim Level: Got em all
Color: red,white,blue
Squatruck317 is on a distinguished road
What is the max pressure that you can run in them?
Old 07-19-2012, 04:36 PM
jgos929 jgos929 is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Lone Star
Color: Sagebrush
Rep:-5
jgos929 has a little shameless behaviour in the past
35psi
I have them in mine and they're a great investment. I leave mine at about 5psi when not hauling anything. I have a TT with a #7000 GVWR and usually fill them to 30psi and get hardly any squat.
