Old 07-15-2012, 02:58 PM
redrumbler redrumbler is offline
Vehicle: 2001 dodge ram 2500
Color: red
redrumbler is on a distinguished road
Default gearing question.
i know its been asked problem well over a million times but i cant find the answer. so maybe yal can answer it for me or direct me in the right direction!
2001 ram 2500 ext cab long bed dana 60s 46 re tranny 5.9l v8 magnum. i have a 5 inch lift with add a leaf in the back with 35 x 12.50 x 16 bfg m/ts and i have 3.55 gears. at 55 im running like 1400ish rpms maybe a little less and at 70-75 im running like 1500ish. i havent really watched it in awhile. i wanna know what rpms you would run with 4.10s/4.11s or 4.56s. i think 4.10s would be plenty i just dont wanna be running any more than 2k rpms or around it. if their is already a thread for this someone just shoot me a link if someone has an answer just let me know!
thank you!
bradley!
p.s. sooner i figure this out sooner im getting gears!
Old 07-15-2012, 03:31 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by redrumbler View Post
. . . 2001 ram 2500 ext cab long bed dana 60s 46 re tranny 5.9l v8 magnum. i have a 5 inch lift with add a leaf in the back with 35 x 12.50 x 16 bfg m/ts and i have 3.55 gears. at 55 im running like 1400ish rpms maybe a little less and at 70-75 im running like 1500ish. i havent really watched it in awhile. i wanna know what rpms you would run with 4.10s/4.11s or 4.56s. i think 4.10s would be plenty i just dont wanna be running any more than 2k rpms or around it.
I ordered the 4:10 gears for my '98 2500 4x4 diesel & I'm running 33" tall tires. 75 mph = about 2100 rpm.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-15-2012, 03:43 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I have a 2010 2500 quad cab long bed with 3.73 gears. At 70-75mph mine runs about 1700-1900 rpm. It has the AAM 10 1/2" rear axle.
Old 07-16-2012, 10:16 PM
KenRamsey581 KenRamsey581 is offline
Vehicle: 2006 2500 4x4 QC
KenRamsey581 is on a distinguished road
For what its worth i have a 2006 4wd 3/4 ton the stock 3.92 ran around 2k@ 70 mph the 4.56's in there now run about 2500 @ 70 mph
Old 07-17-2012, 12:20 AM
Rep:57
That's good to know.
I measured fender openings & calculated gear ratios / tire circumferences before I ordered my '98 so when I placed the order I knew I wanted 4.10's, but to an "old-timer" like myself, just mentioning 4.56's makes you think drag racing, not highway use, 'cause that's the gear commonly run in the '60's & 70's in Super Stock, Modified Production, etc. (The limit in Stock classes was 4.10). BUT -- tires were much smaller in circumference / diameter then than pickup truck tires are today.
Old 07-18-2012, 12:36 PM
Color: red
Thanks for the input so far guys I think I'm gonna run a set of 4.10s I don't drive highway alot just cause I like back roads more haha once I finally get the money and get them in I'll let everyone know
Old 07-19-2012, 10:54 PM
i was skeptical too actually i was kind of scared to do it but i have a good friend who does drag racing and we searched the facts and data ... we came up with the 4.56's and i must say the truck is hands down a different ride it has 35's on it and it will literally eat the back tires off of it if i want it to of course @ 345 a tire i dont do it much !!! This was the best pound for pound mod imo !
35s, gears, lift, rpms
