Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > Dodge Ram 4x4 - Offroad Discussion
Old 07-15-2012, 04:05 PM
tjfbball01 tjfbball01 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
tjfbball01 is on a distinguished road
Default tires??
i understand that this is a 4x4 discussion but i have a 01 ram 1500 2wd. I have a 3 inch body lift and 3.5" fabtech lift with 33" tires. I want to run 35" tires but idk what to get and don't want to spend much money. any ideas? also do you think i would get stuck a lot if i went on ameture/intermediate trails with the 33" or 35"?
Old 07-15-2012, 06:20 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
35's will fit in the rear but not in the front -- they'll hit during a turn and/or with a good deal of suspension movement. As far as getting stuck goes, 1st question is do you have a "Posi" rear end? If you don't have a limited-slip differential, locker or the like, tires aren't going to make much difference when only one of 'em is pulling & the taller you go with tires the taller your overall gear ratio is too.
I ordered my truck with 4.10 (Posi) gears because I intended to put taller tires on it immediately -- standard ratio was 3.57 & going from the stock 28" tall tires to 33's would have dropped that ratio down a lot more. As it is, 75 mph is only 2100 rpm, but that's in the diesel's peak torque range (1700-2700) -- tall tires/gears with a gasoline engine really kills low-end power.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
