Old 07-15-2012, 08:44 PM
95ramstang02 95ramstang02 is offline
Vehicle: 1995 dodge ram 1500 SLTLaramie
Trim Level: SLT Laramie
95ramstang02 is on a distinguished road
Question will they fit
95 ram 1500 2in leveling kit will 35in tires fit or how much will they rub?
Old 07-15-2012, 08:50 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
35's will fit in the rear but not the front -- I measured that even before I ordered my '98 2500HD 4x4. And brand-new BFG Mud Terrain 33's will rub in the front when you turn the steering wheel most of the way left or right, but once they get some miles on 'em that'll go away -- All Terrains will clear new.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-16-2012, 01:30 AM
Im looking at 35 a/t tires yes or no
Old 07-16-2012, 07:24 AM
Rep:57
No. As I said, they won't fit in the front, although they will in the rear, so a 2WD truck could have 35 rear, 33 front. But if you want to stay the same size with all 4, then 33" is the limit to avoid clearance problems.
