90 Dodge D-150 wont start HELP - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 07-16-2012, 02:32 PM
orluna84 orluna84 is offline
Vehicle: 1990 Dodge D-150
Color: Silver and Red
orluna84 is on a distinguished road
Default 90 Dodge D-150 wont start HELP
Got a 1990 D-150 318 Having trouble getting it going again. Problem started after jumping off another vehicle. Was running fine untill i turned it off. Now it wont start. It just clicks. I no it seems very simple but i've had the starter tested, checked the battery, connections, changed coil, and the starter relay. I'm out of options. If someone gots an idea id really appreciate the help.
Old 07-16-2012, 02:44 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Check for fuseable links & relays where you're not expecting them to be -- need a service manual schematic. I had a similar thing happen to my 1990 (Ford) van & come to find out there's a fuel cut-off safety switch in the kick panel on the passenger's side that burnt thru when the alternator overcharged. Can't see the switch until you pull the panel part-way off, but it was shown on the schematic. That one cut the voltage to the electric fuel pumps so they wouldn't work (switch supposed to operate in a bad wreck to reduce the possibility of a fire), but I've seen others that killed the ignition system, or cut power going elsewhere.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-16-2012, 02:54 PM
Yeah i never got a book on it. I guess it would help if i did. The only other thing ive heard so far was that it could be my powertrain controle modgule might have fried while i was trying to jump off the other car.
Old 08-24-2012, 09:55 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Can you turn over the engine by Hand or with a wrench, have you checked the starter itself or the ignition switch. just more to think about.
Old 08-24-2012, 10:11 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd say the fusable link too. Check the wires coming off the battery. If you bend them or follow 'em and with your hands about 6 inches apart try to stretch them and follow them as far as you can doing that. The link is usually pretty close to the battery. So if you feel a weak spot in a wire or one stretches that's where the problem is.
Old 08-26-2012, 08:54 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
If you're getting an electrical click, I'd make sure the battery is ok, double check all batttery connections as well as both the engine and radiator support ground wires, then I'd look to the starter.
Old 09-03-2012, 11:03 AM
moparornocar72's Avatar
Rep:630
Fuse box is not very big and located behind the dash, I would check every single fuse as well as what others have about the fuseable links!
14.268 @ 95 MPH Full Trim
Old 10-15-2012, 11:14 PM
Trim Level: base
Color: blue/silver
I have just had a simular problem with my lights. I had a bad relay for the lights. Mine still had headlights but none of the rest.
