Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 07-16-2012, 05:54 PM
blkdodge919's Avatar
blkdodge919 blkdodge919 is offline
Vehicle: 2010 Dodge Ram Quad Cab SLT
blkdodge919 is on a distinguished road
Default Need help with exhaust exit through body or bed
I have been looking everywhere online for an exhaust tip/flange that exits through the rear rocker panel or anywhere for that matter....all the links to the one stylintrucks.com had are dead and the only other thing i have been able to find was around $300 for an all stainless steel tip...thanks for any help
Old 07-17-2012, 01:43 AM
Vehicle: N/A
Rep:1045
Are you talking abouy cutting out a section for the tip? Idk about buying one, but mr.lopar made one for his 2g on his build thread.
Start
Post 17 - http://www.ramforumz.com/showthread.php?t=90628&page=2
Finish
Post 25 - http://www.ramforumz.com/showthread.php?t=90628&page=3
Old 07-17-2012, 01:59 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Check with fabricators like Pro Fabrication in Concord, NC (suburb of Charlotte) & Woolf Aircraft in Michigan. Pro Fabrication has a 3" stainless pipe which flattens out to a wider end, similar to what NASCAR cars use to run the exhaust out the side for about $35 that I was looking @ the other day. There are several other styles too.
I ended up buying a 14" long polished stainless tip with a perforated baffle inside that goes from 3" to 5" for the exhaust I run out the side of my pickup, in front of the right rear tire -- that tip was $32 @ a local Advance Auto store. And unless you are a fabricator you'll want to find one locally to do the installation work / cutting on the body, etc. If you don't do it right the 1st time it'll be "rust city" in no time & it's not something a typical body shop can do.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-18-2012, 05:39 AM
I was going for a NASCAR type look....if you google image search through body exhaust one of the first pictures it shows is of a flange with dual tips inside it...its made as a one piece unit though...thanks for the info
