4WD Issues - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-14-2012, 01:14 AM
GrahamL GrahamL is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: SLT Lariat
Color: Green
GrahamL is on a distinguished road
Also, if you do need to take off your front driveshaft here is the way that was easiest for me. Take the clamps off the u-joint at the front of the driveshaft. Remove the clips from the u-joint caps and slide the shaft to the side out of one of the caps and let it hang, you will need to pop one of the u-joint caps off. Move to the back where the shaft bolts to the transfer case and turn the shaft til you can get your wrench on one of the bolts and lock it into 4wd so you can get the leverage to break the bolt loose. Put it back into 2wd and repeat for the remaining three bolts.
